Toshiba 62HMX84 62" Rear Projection HDTV Logo
Posted on Oct 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
62hm85 cracked inner screen - Toshiba 62HMX84 62" Rear Projection HDTV
Abcd
Level 2:
Scholar:
  • Expert 70 Answers
  • Posted on Nov 01, 2009
 Abcd
Expert
Level 2:
Scholar:
Answers
70
Questions
0
Helped
24000
Points
135
If the screen cracked from daily use and was not cracked on the outside of the set,then you are entitled to a replacement or to have the tv repaired under warranty from a manufacturing defect. If the outer glass panel is not damaged and the internal screen is,then call the manufacturer.
How do you tell if you you have a cracked tv screen
That's it. Cracked inner screen(LCD screen.)
1helpful
Plasma inner screen cracked, and buzzing. Is it worth fixing the caps?
It sounds like this is an LCD tv - not a plasma.
chances are that if the screen was hit hard enough, at least one of the CCFL bulbs for the backlight broke too. This created a fault in the inverter circuit, cauing a shutdown after a second or two.
What would cause the inner screen to crack?
Humidity or rapid temperature differances. Also sometimes the force from impact can transfer to the inner screen instead of the outer screen.
I have a Sony KP-46S25. The screen is cracked. I
There are 2 screens for this set, a protective (outer) screen and a fresnel (inner) screen. Which one needs to be replaced?
Dan
Screen is blank/ w. small horizontal lines going across it
It sounds as though you may have cracked you screen or damaged the LCD cable. This can be hard to tell because many new phones have an outer screen that does not crack when the inner one does.
There is a crack in my inner screen in my phone
Most likly you cant fix the screen, you might be able to replace the screen or the phone.
2answers
Cracked Screen Protector
what is the model number for you set. is it a hd52w56 or something like that. on that model it is called the super sheild. is the inner screens damaged.. if just the outer screen that runs 200 or more. i have seen people just replace the plexiglass on it. the inner screens run about 250
I ve got a cracked inner screen on a rca d61130 any help
it is compulsary to replace the screen.calling a technician is much advisable if you dont have any technical knowledge.
you can do it your self by removing the old screen by opening the locks on the inner side and removing the screws from internal side.
thanks.
1helpful
My rca d52w19 has a cracked screen,
is the inner screen damaged? or just the outside. the outside is called the super sheild. this can be purchased at union electronics
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
