Question about Samsung HCN5527W 55" Rear Projection Television
Pico/ Resistors what are these??
How do you CHANGE 2 CONVERGENCE ICS.STK392-040.AND ALSO CHECK THE 3.9OHM RESISTORS NEARBY AND REPLACE ANY OPEN ONES,IF ANY.LASTLY CHECK 3.5 AMP PICO FUSES MAKING SURE THEY ARE NOT OPEN do this???? WHats a pico fuse what do they an the resistors look like How do you know if there open , how do you close them???????? please help with pics if possible Thank you!
  • 579 Answers
Pico means small and these look like little small resistors, but don't have stripes like resistors, just part numbers. They should measure as a dead short and be in the immediate vicinity of the STK's
Posted on Jan 03, 2008
    Sergeant:
  • 395 Answers
Make life easy on your self call a tech. if you don't know the basics of electronics such as ID ing a resistor or pico fuse or simple solder/ desoldering you shouldn't attemp this repair!!
but if you are so inclined to repair this your self replace the whole convergance board part# BP9500142P it will be much easyer.
Hi there i replaced my hitachi 53uwx10ba convergence IC (2) stk392-120 and now it won't turn on and just flashes at the front panel 7 times, can i get some help pls
Did u check the pico fuse and all those resistors on the tv convergence board to make sure with ones are good resistors which are not good resistors and replace all them resistors too?U didn't do that should get it tested and replaces all those dying resitors.Try website like Tvrepairworld.com look up ur Hitachi tv model what resistors and pico fuse u require to check.
Aug 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I replaced my convergence chips and I still have a convergence problem. Its not as bad but I still cant line up the blue convergence cross exactly
Sounds like your over half way there lol..
You now need to check the resistors positioned near the convergence ic's. They are your likely problem and go bad often when the ic's fail.
They are normally about 2watt and the values will vary but normally are like .10 ohms to 1 ohm.
I cant find a schematic to give you the exact values and locations but if these resistors measure off value at all you need to replace them with the exact value of the originals.
Heres a link to resistor color code guides just in case the value numbers are not printed on the resistors
http://www.dannyg.com/examples/res2/resistor.htm
Good Luck!!!
Nov 24, 2010 | Panasonic PT-53WX42 53" Rear Projection...
I just replaced the 2 Convergence IC's now i have a bad pitcure
Yes, did you check the group of identical 3.9 ohm blue resistors in front of the chips? If even one is open or discolored in the middle convergence will not adjust in some area.
SD TECH
Feb 02, 2010 | Mitsubishi WS-65907 65" Rear Projection...
As I plan to do my convergence repair for my 46" projection tv,resistors are mention to be replace aside from the 2 convergence IC's as well as the 6 pico fuses ( 2 for the G board and 4 for the D board )...
Just replace Both of the STKs but CK all the pico fuses in front and behind STKs they are yellow or green 5amps 6amps For Parts Call Mats Electronic 1-800-628-1118 I have changed out alot and so far have never had to replace any resistors.
Nov 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
The colors are distorted and there is triple images
triple images show failure of convergence out ICs in TV, these are two big black ICs mounted with aluminum heat sink on D board, replace these ICs with same number STK392-560 and problem in your Sony KP-46WT510 will be solved.
Required ICs are available in Part Store.
Let me know any further question, if any.
Thanks.
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence parts? What are the specific pico fuses and resistors
There are six 3.15 amp picos use 3.5 amp when replacing and there are two 5 amp picos on the G board the resistors if needed are 4.7 ohm 1/2watt
Sep 06, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp 51ws510 convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 19, 2008 | Sony KP-51WS510 51" Rear Projection...
Trying to find the fuse and resistor locations
did you replace the picos and check the 4.7 ohm resistors / Thats usually whats wrong when the old ICs go out they take the picos and often some of the resistors as well.
Sep 22, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Convergence
there are a series of 4.7 ohm 1/2 watt resistors all in a row under the fins of the ICs. Check them they have to have one side unsolderd to check them. There are also 6 yellow pico fuses in that line of resistors that need to be checked as well.
Jul 05, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Samsung HCN5527W 55" Rear Projection Television Logo
171 people viewed this question
Jerry Greenberg
Jerry Greenberg
