Question about RCA P61927 61" Rear Projection Television
CONVERGENCE GRID IS OFF ON MY RCA P61929
HOW TO YOU FIX THE CONVERGENCE GRID ON THIS TV.
iT APPEAR AS IF THE COLORS HAVE SEPARATE. CAUING THE TV TO BE LIKE A GHOSTING
  • MATT8821 Jan 03, 2008
    Where can I get a replacement part and the part number?
    And what is the price range?
    This information will be very helpful in fixing my TV
  • Tim_W Jan 06, 2008
    My RCA P61927 61" projection TV has a very similar problem. I have the hour glass effect on the screen, but I also have a double-image. The second image is just slightly to the side of the first. How do you set the convergence for this tv, I cannot find a setting for it on the remote or the menu screens.
    Thanks...
  • 579 Answers
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it. If that doesn't work the nodules need replacing.
Posted on Jan 03, 2008
  • Greg Collins Jan 03, 2008
    The part number will be on the module itself. Starts with STK _ _ _ _. They cost about $20 ea.
Akai rear projection tv...picture is not deformed....however there are images (Ghost image) in separated colors...like 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 24, 2010 | Akai PT5598HD 55" Rear Projection...
The problem I am having is with the convergence of the tv. I use the television for cable, and for video gaming. The cable box works fine, but the playstation is where I run into problems. Games supported...
RCA Tvs have to be adjusted each independently for each format such as 480 and 1080. You can get the ITC222 series convergence and alignment CD from www.tvrepairworld.com which will explain exactly how to do it
Jun 18, 2010 | RCA HD52W56 52" Rear Projection HDTV
It is like looking at 3d in all three colors. i
  • Screen looks 3D
May 30, 2010 | RCA D52W19 52" Rear Projection Television
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
  • Screen looks 3D
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Convergence adjustment
  • Screen looks 3D
Apr 30, 2010 | RCA P52926 52" Rear Projection Television
I have a RCA R56WH78YX53 tv that made a pop or click noise and now the picture is bowed and the colors look like you need 3D glasses. I tried to do a convergence but the tv went blank and now it will not...
  • Screen looks 3D
Feb 27, 2010 | RCA HD52W59 HDTV Projection Television
Color balance is off.
this my good sir, (or mam), is a convergence issue. very common rca failure. there is a convergence power module that has a 130volt regulator that goes bad. this can be fixed in-home by experienced technician for less tan 300.00 including parts, labor .& service call. the chip is an stk730-150. mch
Mar 09, 2009 | RCA P61929 TV
Convergance,and distorted projection,colors will not align
These tv's have a separate convergence power supply that goes bad. This will cause the problem you are having. Depending on the age of your tv, the board may be available
Dec 07, 2008 | RCA P61927 61" Rear Projection Television
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
RCA P61927 61" Rear Projection Television Logo
244 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
