Question about Kenmore Oasis HE 27062 Top Load Washer
Washer not running correctly
When you push the on button nothing happens. When you push the off button it turns the washer on. But it doesn't stay running. Then it starts beeping. This is not my washer, it belongs to a friend of mine. And this is sort of a 3 way relay communication. But they have no other sources to turn too.
REPLACED BELT WONT WORK
Posted on Jan 03, 2008
6ya staff
SOURCE:
Why wont my washer to perform the system clean cycle?
Hello Larry Occhipinti, thank you for your post!
If you are pushing the necessary buttons on your Frigidaire washer to perform a system clean and they are not working, it could be a possible issue within the control panel. I would recommend a reset on your appliance which can be done by disconnecting power from your appliance for roughly ten minutes. If that does not correct the issue, you can run a hot water wash cycle with a cup of bleach inside the tub to clean your appliance out as well. I hope this is helpful. -Matt
Aug 31, 2014 | Frigidaire Affinity ATF7000E Front Load...
When I push the tub clean button on my LG Washer WM2688H, nothing happens. How can I fix?
I would go to the LG website and look up the manual for this model. All of the 'push button' control panels have a particular sequence which must be followed in order for them to operate correctly.
Jun 13, 2014 | LG WM-2277HW Front Load Washer
The door lock stays lit and when I go to turn it off nothing happens. None of the controls work.
First you can try unplugging for about fifteen minutes or so. If that doesn't do it then it is your safety switch on your washer.
May 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The machine is turning on, but when I push the buttons, nothing is happening
You can try resetting your washing machines operating sytem.
Turn the washer OFF
Standing on a dry floor, unplug the washer from the outlet
Wait several minutes
Replug the Washer into the outlet and turn it on.
Please let me know if this works for you.
Dec 20, 2010 | Haier XQJ50-31 Top Load Washer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Whirlpool Duet Front Loading Washer Won't Turn On
MY WASHER WAS DOING BASICALLY THE SAME THING. I HAVE A WHIRLPOOL FRONT LOADER MODEL #GHW9460PL0. MY HUBBY REMOVED THE 3 SCREWS FROM THE BACK OF THE WASHER, UNPLUG IT FIRST, AND TOOK THE TOP OFF. WE THEN CAREFULLY UNPLUG THE WIRES AND REPLUGGED THEM BACK IN 1 BY 1 SO U WONT GET THEM MIXED UP. WE THEN TRYED IT, AND THE CONTROL LOCKED LITE STAYED LIT. HE HELD THE SIGNAL CYCLE BUTTON IN FOR 3 SECONDS AND THE LIGHT WENT OUT. WE THEN TRYED RUNNING A CYCLE AND SO FAR SO GOOD!! GOOD LUCK!
May 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
Apr 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer won't start - lights up but won't stay on
have you tried pushing the button twice? That's what I have to do.
Jun 05, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
59 people viewed this question
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
