Question about Epson RX595 Photo All-In-One Printer
Problems printing from my Epson RX 595
I try to print and keep getting the error message "Close the scanner unit",
unfortunetly I have the unit down.
  • 2 more comments
  • rustler6 Apr 05, 2008
    rustler6
  • Valjay May 11, 2008
    Yes, I just installed my RX595 and can't print -- what's wrong? It says "Close the scanner unit" but it is closed. Everything's buttoned up. This is very frustrating, as I have not been able to test one single copy yet. And of course I bought this through the mail so try getting help fixing it. Does anyone have advice on how to fix this problem? Your help is appreciated!
  • justin78 May 14, 2008
    I got the "close scanner unit" error message and spent 20mins on the phone with Epson's tech support who eventually determined that it was a hardware issue. After recieving the new one, (they sent it prior to me sending back the old one so I know it was a different printer), it had the exact same issue and will not print at all, though the scanner functions just fine.
  • kelman Aug 21, 2013
    i have a solution guys..... before printing, go to control panel>printers and faxes>right click on your printer>click printing preferences>select best photo>ok
I just purchased an RX595 to replace my R380, which went belly up after only a year.
To fix the "close scanner" problem, try placing weight on top of the scanner. Its annoying to have to keep a stack of DVD's on top of my printer, but it works.
Epson needs to refine their products and quit raping people on ink. People talk about "Big Oil" what about "BIg Ink?"
Posted on Jun 23, 2008
  • Epson Master
  • 1,879 Answers
>disconnect the unit from the computer
>try to make a standalone copy
>if the message still appears on the printer´s LCD screen, hardware issue
>contact vendor for warranty
Posted on Jan 03, 2008
Erro! paper id jammed in the printer, turn off the printer, open the scanner unit, remove paper see your documentation.
Posted on Apr 15, 2008
SX415 Error message A printer error has occurred - switching off and on again results in the same message.
Diagnosing the Problem - Epson
https://files.support.epson.com/htmldocs/rx620_/.../trble_1.htm
EpsonAn error has occurred in the printer parts. Turn this product off, and then back on. If theerror message still appears, contact your dealer. Scanner error occurred.
Epson printer sx415 printing problems/paper jam - Forum Thread ...
www.pcadvisor.co.uk > Forums > Tech Helproom
Jun 30, 2010 - Epson printer sx415 printing problems/paper jam ... before it will work correctly again otherwise you will continue to get the error message.
Oct 08, 2015 | Epson Stylus Office Equipment & Supplies
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Windows 7 is not recognizing me Epson RX595
The following steps may help:
  1. Remove all the drivers and software installed for this printer.
  2. Restart your computer.
  3. Click here to go to the driver download page. Download the driver for Win 7 and install.
  4. Connect the printer to your PC, the installation will continue.
  5. After installation, you should be able to use your printer.
Nov 03, 2009 | Epson RX595 Photo All-In-One Printer
E-90 error message on Epson CX6000
If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the Stylus CX.
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the Stylus CX back on.
Also
If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  5. Close the scanner.
  6. Turn the Stylus CX back on.
Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson RX 595: Yellow streaks in black
In the printer settings, there is a button to switch to Advanced.
So, right click on the printer, select properties, click Advanced, then Printing Defaults, then there is your switch to Advanced button. That will reveal the tick box that says only use black.
Mar 05, 2009 | Epson RX595 Photo All-In-One Printer
Error Epson RX 595- Close the Scanner Unit
I just had the same problem. I figured that there must be a lever that gets pushed in when the lid closes and sure enough there's a square hole in the vent area (look in the area below the serial number) and in that is a small lever is that gets pushed down by the piece that's attached to the lid. For some reason, it's not pushing it down far enough or the lever has bent and it doesn't connect. My only solution (for now) was to jam a pencil into the lever to push it down all the way and sure enough, it worked. I'm sure there's a better, more permanent (and more attractive) way to repair this, but for now, it works and I need to print out 60 copies of an event program for tomorrow night! Good luck!
Jan 24, 2009 | Epson RX595 Photo All-In-One Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson RX595 Photo All-In-One Printer Logo
1,110 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
