Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Motorolak1 how to hook up shortcut to stored numbers
    Brigadier General:
  • 7,752 Answers
Will check that out for you
Posted on Feb 13, 2008
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Tip
    Sony Ericsson Secret Codes
    SONY ERICCSON SECRET CODES:
    On the main screen type
    Sony Ericsson Secret Menu: -> * <- <- * <- *
    (-> means press joystick, arrow keys or jogdial to the right and <- means left.)
    You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels.
    You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests)
    IMEI Number: *#06#
    Lockstatus: <- * * <-
    Shortcut to last dialed numbers: 0#
    Shortcut to sim numbers: On main menu type a number and press #
    If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press < 0000
    on Dec 15, 2009 | Cell Phones
    How to store numbers using panasonic KX-T7630
    Hello Jd,
    For storing numbers in panasonic KX-T7630
    While on-hook Enter phone number(max. 32 digits). AUTO DIALSTORE OR Press STORE or ENTER. Enter name(max. 20 characters). AUTO DIAL Store or Pres STORE or ENTER.Press Exit or Pause.
    Aug 18, 2011 | Panasonic KX-T7630 Corded Phone
    We have an old Unisonic model 9325 corded phone that has the capability to program phone numbers in it but cannot find the manual. Any way to get instructions on how to program with numbers?
    I have an old Unisonic 9725, and the programming method for that phone may work for yours.
    1. take handset 'off hook'
    2. press: store
    3. enter phone no.
    4. press store
    5. press memory button 1, 2, or 3...or 0-9
    6. put handset back 'on-hook'
    to use: take handset off hook, and press the memory number that applies.
    Jul 03, 2010 | Unisonic (9742) Corded Phone
    How do I delete a fax number that is no longer needed?
    On the panel, go to menus > manage shortcuts > choose the number > hit delete. You can also do it in the embedded web server interface. go to settings > managa shortcuts > fax shortcuts, click on the number, then hit delete. Hope this helps. If you need more assistance, just leave a comment and I'll get back to it. Thanks.
    Jun 29, 2010 | Lexmark X736de Mfp- Product Specs Tbd...
    NO MENU SHOWN
    The only way to reset your phone is by pressing the center button key (in the middle of the navigation keys) while turning the phone on.
    Dec 27, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
    I deleted my cyberlink youcam shortcut in my compaq v3700,however it said it does not reinstall the program but just deletes the shortcut which is not found in the recycle bin too.. how do i go about with...
    Sir,
    Right click at desktop go to New->shortcut->it ask the location of which the program is stored. click the location C:\ of that software. It will be created the shortcut
    Thanks Good luck
    Aug 10, 2009 | Acer Aspire 5100 Notebook
    How do you set up speed dial?
    http://www.home-electronics.net/ge/pc/IB/29385GE1_IB.pdf
    here is the owner manual , to much to type , but start at storing a phone number in MEMORY , start reading at the word MEMORY in the user guide .you need to list a phone number in memory and then assign a number to it for future speed dial , yet they use the term memory . can be accessed while on the hook or off .
    Jan 01, 2009 | GE 29385GE1 Speakerphone
    Audioline 20 Memory Speakerphone
    1. Lift handset (releasing hook switch).or just press SPEAKER, ignore any noises or BT messages while you..
    2. Press and release STORE key.
    3. Press the keys for the telephone number
    you wish to store.
    4. Press and release the STORE key again.
    5. Press the keypad number (0-9) you want
    that telephone number stored in.
    6. Your number is now stored.
    Apr 01, 2008 | Audioline TEL 100 Plus Corded Phone
    Storing web shortcuts on my V3
    when u log on to fixya web site towards the right hand side u can find out the motorola RazrV3.
    click it and follow the instructions.
    Feb 20, 2008 | Motorola Mobility RAZR V3
    Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
    15 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
