Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi projection TV
My TV turns ON but no picture only volume. Before coming to this state the picture was concave sometimes turned completely red.
  • Anonymous Jan 27, 2008
    SOUND NO PICTURE
  • 579 Answers
Try to re-solder the circuit board that contains the STK392-570 convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. This is a caused by a minimum effort (a.k.a. minimum cost) solder job, probably done in some 3rd world sweat shop. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests. Best of luck, hope ya fix it. If that doesn't do it then the amps need replacing.
Posted on Jan 03, 2008
    Genius:
  • 1,153 Answers
Do the self test first to get the error codes
Picture appears concave and shrunken and pulses in size
Replace Both of your STK convergence ICs STK392-570 If this is not number on your s use what it has on them. you can call MATs 1-800-628-1118 o Main STK is what is going bad when IC goes out all together TV will shut down and will not come on. So replace BOTH STKs ASAP! you will also need Heat sink compound to put on back of New ICs.
Aug 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Rca picture concave 52 in rear projection
sounds like your color guns are out of alignment and need adjusting. its a cheap fix with a tv tech but i wouldnt recommend doing it yourself. plus, a visit from a tech can tell you if there is anything else wrong/about to b wrong
Oct 21, 2008 | RCA P52939 52" Rear Projection Television
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link http://download.jazel.net/misc/filecache/b8/b89bca4c8b740315d378e8ed030461c5_1227-517SeriesOwnersGuide.pdf and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi TV problem ws-65809 Concave Screen Fix
No, but I do paid phone coaching for such things. Contact me directly and I'll steer you past the dangers and in all the right directions.
Mr Bob
www.imageperfection.com
May 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi 57" HDTV - has sound and timer light flashes
I had the same problem and my local repair guy soldered a defective sensor so that it goes around that problem. I also had to buy a new bulb. Now my picture is "cloudy" and the repairman has no idea why. I am waiting for them to call back on it.
Mar 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Mitsubishi VS 45501A Projection TV
Model VS-45501A  probably not worth fixing at around 400.00
for a convergence circuit overhaul......T.
Oct 20, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
