Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
NOTE-(This may be a leveling issue as well)
It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
he knows his stuff!
" - tulsaholmes
Popular Solutions for Frigidaire FRS26H5AS Side by
the crisper drawer supports on the front have broken off how do I get them out ? fridge model #...
(More)
the crisper drawer supports on the front have broken off how do I get them out ? fridge model # FRS6LR5EW5 I found the replacement part here http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=240423701&productGroupId=0046&supplierId=253&brandId=1428&documentId=R0608036&keySuffixId=NA&modelNumber=FRS6LR5EW5&keyId=0100&pageId=00003&productTypeId=0165000&searchModelNumber=FRS6LR5EW5&subCompDesc=Cabinet&brandDesc=FRIGIDAIRE&modelDesc=REFRIGERATOR&blt=11 but cannot remove the old ones. please help!
I have replaced my water filter several times to no avail. We have constant leakage from the filter...
(More)
I have replaced my water filter several times to no avail. We have constant leakage from the filter area. At first I thought the new filters were defective. (replaced 3) I have followed the Frigidaire manual when replacing the new filter...and gone through all the recommended steps...HELP !!
