FixYa.com
Tags:
GE Quiet-Aire Ductless Air Conditioning Split System, AS1CD12AA0/AS0CD12AA0 Air Conditioner
20 year old central a/c heater not working
posted by isidro68 on Jan 02, 2008
I have an old house, my central unit heater is not working blows cold air not hot air when i need it. Is a GE unit, dont know the model
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 12, 2008
Not Rated (0)
bobotfel
Rank:Wiz Wiz
Rating: 83%, 135 votes
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Air Conditioners problems?
Air Conditioners
heater has stopped working, no
heater has stopped working, no... Answer This...
Air Conditioners
intertherm 3 ton ac unit
intertherm 3 ton ac unit I took... Answer This...
Air Conditioners
Fan runs, but when compressor
Fan runs, but when compressor... Answer This...
Air Conditioners
I wish to change the
I wish to change the set temp... Answer This...
GE Quiet-Aire Ductless Air Conditioning Split...
GE mini-Split Error code
I am currently trying to... Answer This...
Repair Service
Find Air Conditioner Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
