If you have a touchpad icon down in the bottom right hand corner on windows task bar click it and you should see a menu that comes up. In that menu you should see tap to click. click that to disable your clicking for the touchpad.
If the option is not there go control panel and click on hardware and sound, then devices and printer. under devices and printer you should see mouse or mouse properties. There should be a option in there to turn it off too.
1. Go to the "Control Panel" and double click on the "Mouse" item. 2. Go to the "Buttons" tab in the "Mouse Properties" window. 3. From the "Devices" drop-down menu, select the touch pad device. The options in the "Buttons" tab will change. 4. Find the check box which turns on/off clicking & enable clicking. 5. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion dv4000 PC Notebook
My left clicker on my trackpad has been loose for a couple weeks, now it is extremely hard to click....
(More)
My left clicker on my trackpad has been loose for a couple weeks, now it is extremely hard to click. The little key can pop out and in easy and i noticed it might have something broken on it. i need to find a replacement. Where can i find it?
Have been using my MP G3010 scanner for 2 yrs. Suddenly, won't work and get...
(More)
Have been using my MP G3010 scanner for 2 yrs. Suddenly, won't work and get "DocumentViewer.msi file is missing" Can you help?
ho dovuto riparare il sistema operativo con l'inserimento del CD - tutto funziona in maniera...
(More)
ho dovuto riparare il sistema operativo con l'inserimento del CD - tutto funziona in maniera ottimale ma nella guida in linea resta vuota la sede dove dovrebbe apparire l'indice di ricerca alfabetico
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
