Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
Router not working unless
My Belkin Router has worked without error until recently. I have both a desktop and laptop the laptop will only work (internet) when desktop is turned on.
  • ddavid Jan 04, 2008
    wired just as you described. We don't have to log in to get on the internet. Insightbb is my provider.
  • 556 Answers
Several questions --
How is this wired?
Comming from the Cable (tv) or a phone wire (DSL) from a phone jack you are connected to a modem/whatever supplied by your service provider. Then an ethernet cable (looks like a fat phone cable with extra wide connectors (8 metal connectors instead of 2 or 4) connects the modem/whatever to your router's WAN port (the separate port not one of the block of 4) and another ethernet cable connects the one of the outer's Lan ports (probably block of 4) to the desktop computer and your laptop operates wirelessly. Is this correct? If not explain houw this is wired, please. For consistency please start at the cable or phone wire.
Does your desktop do anything to log into the internet with a userid and password maybe?
If so who is your internet service provider?
We may need to change the login process and get it into the router and off the desktop.
Posted on Jan 03, 2008
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Belkin router problems
Its not necessary to purchase a new router. Nintendo DS supports WEP encryption. You wont be able to connect if the encryption on the router is WPA. Your computer can connect on both WPA and WEP so what i suggest is for you to access the router page then check the wireless settings then change the encryption to WEP so that your Laptop and DS can connect at the same time. To access your router check the manual for the username and password
Thanks for using Fixya.
Aug 03, 2010 | Belkin (F5D5231-4) Router
Laptop stopped connecting via wifi to home network.
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
Dec 31, 2009 | Belkin (F5D7231-4) Wireless Router
My router drops connection when I try to add security
did you try to upgrade teh firmware of the router ? that could be a probable solution . Also try to change the channels in the router. Make it to 6 or 11. Sometimes that could help
Thanks Ranjit
Sep 24, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My Belkin router not working...?
You've not given enough information to receive a straightforward answer. I assume your problem is that you can't connect to your Belkin router, and that you are trying to connect wirelessly? When you do a site survey (that is, when you click your little antenna icon to 'View Wireless Networks' in the area), do you see anything?
A common problem with wireless on laptops is that the user will accidentally turn it off without realizing. There's usually a switch on the side of the laptop that'll turn on or off your onboard wireless (to save on battery power). Switching that will often resolve the issue.
May 19, 2009 | Belkin (F5D5231-4) Router
Laptop dell Vostro 1500 / Belkin N1 Problems for to connect to Internet
try resetting the router and the modem at the same time. then if that doesn't work try restarting your computer, like digi2112 said try upgrading you firmware
Oct 24, 2008 | Computers & Internet
Lost internet connection
If you have left your router open, you may have been hacked.
Ring Belkin support to make your router more secure
Oct 11, 2008 | Belkin (F5D7230-4) Router (587009)
Problem with connection to router and DSL
I would go to run and type in cmd. then type in ipconfig, I believe that is right for windows 98. I would look on there and see if that is getting a correct IP and if the DNS server says if it is a belkin router. ipconfig /? will give you the commands you can use with that. There is a ipconfig /renew that will refresh them all. You might have it set to be a static IP and you would want it to be dynamic and have it refresh by itself. You can go to for directions to change it to dynamic, I would just do the opposite of what they suggest to make it auto config. It sounds like it is looking for a previous DNS server which is not there anymore because the DSL connection reset.
Dec 20, 2007 | Belkin (F5D7230-4) Router (587009)
Belkin modem router
Check all connections from PC to router...
Unplug/re-plug... you should see notifications...
Dec 13, 2007 | Computers & Internet
Belkin router and modems
i would suggest returning the router and/or purchase a modem router, as it does away with all the connection problems and the need to click dial to connect as a modem router is always on and does not require a main pc to be on. It will also probably be cheaper than buying a seperate modem.
Sep 13, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
