Hi my husband purchased me a RCA audio shelf system just
lastyearforChristmas. 1 year old. The other day I put cd's in it
(willhold5 cd's) and cd changer spins like it is suppose
to.Thereadoutwill say "read" then it will go to the next cd then
samething"read"then when it has gone thru all the cd's it will say
"nodisks"and itwon't play. Did I push a wrong button on this thing? or does it need service? Please help if you can. Can't listen to Elvis anymore bobdarrv@localnet.com
-   I have the rca rs2656 and when I put in discs it says read then skips and goes to the next disc till it has skipped through all 5 discs. I have put in the cleaner disc and it will not read.-   jdickerson
Sounds like the reader (laser eye) is dirty. The reason why it says "read" is beacuse it is looking for a disc to play, it's not actually reading the disc, more like searching for data to read. Even if you have all five discs in it still won't play. It's like looking through a dirty windsheild, nowing that there is a road there but you can't see it. This is a very common problem and is easy to fix. Go to your local Walmart, or electronics store and purchase yourself a cleaning CD. It will look like a regular CD but with small brushes on one side and might come with some cleaning solution too. Shouldn't cost more than $20.
i had the volume up and the system cut out and when i got it turned on again now i cant get the sub...
(More)
i had the volume up and the system cut out and when i got it turned on again now i cant get the sub speaker to work
Want to use use my direct tv remote to use with my RCA RS 2656 shelf system. What would the remote...
(More)
Want to use use my direct tv remote to use with my RCA RS 2656 shelf system. What would the remote codes be.
