Samsung HLP4663W 46 in. Rear Projection HDTV Television
Problem for Samsung HLP4663W 46 in. Rear Projection HDTV Television
Tv keeps shutting off for no apparent reason
By gman82655 on Oct 31, 2009
tv keeps shutting off for no apparent reason
Solution #1
posted on Oct 31, 2009
Somewhat Helpful)
toddthetvmd
Rank: Guru
Rating: 92%, 23 votes
Hi, it may be your lamp door switch. This is a common problem with DLP/LCD projection TV's.
You can by-pass it. You do not need it,unless you plan to stare at the light when it is on and ruin your eyes.Take the lamp door off,There is a little blue switch,disconnect the wires fron the connector,or simply cut the 2/or sometimes 3 wires. Connect them together. And tape then.Do not worry about getting shocked.only 3.4 volts. But do this when tv is un pluged. Due to bright lamp. it you feel uncomfortable doing this,Just tape the switch in the on posisition. Either push it foward or backward. in the middle it is in the off position. If still has a problem,replace the lamp,if you did,it may be your DMD board. That gets costly. And needs to be replaced by a tech. Not a easy task.Also of lineing up to do,and adjusting. Pain in the ... Hope the switch is the problem. Todd toddthetvmd@yahoo.com
Was this helpful?
Yes
No
Popular Solutions for Samsung HLP4663W 46 in. Rear
Questions and Unsolved Problems for Samsung HLP4663W 46 in. Rear
Do you recommend Samsung HLP4663W 46 in. Rear Projection HDTV Television?
Answer
Answer
I replaced the lamp and Ballast in my Samsung HLP4663W; still no picture
Answer
I thought it was a fan problem but they both work. If I watch the tv for a while the picture just... (More)
Answer
lost remote and cant turn on tv stays in standby/temp mode
Answer
How much would it cost to fix pixels for a 46'' samsung tv there hundreds of white dots on it?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HLP4663W 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 764
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
