Amana ABB1927DE Bottom Freezer Refrigerator
Problem for Amana ABB1927DE Bottom Freezer Refrigerator
Our Amanda refrigerator/freezer has been making
By dyamin on Oct 31, 2009
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every 5-10 minutes. The blower and light still work. The unit is about 4.5 years old. The refrigerator seems to still be working.
Solution #1
posted on Nov 11, 2009
Not Rated)
jackfrost555
Rank: Guru  Refrigerators  Expert
Rating: 92%, 72 votes
Good day,
As a general rule, if the freezer is thawing, but the food compartment seems decent, it is usually in the compressor, or condenser fan motor area that cools the compressor.
Remove the bottom back cover, and try to determine if the problem seems to be coming from that area. If that fan motor, the condenser fan motor, is giving you problems, then if handy, you can change it yourself. But if any question it might be coming from the compressor itself, and since you have only 6 months warranty, on that pricey item, it might pay to have the selling dealer perform a service call for you.
Was this helpful?
Yes
No
Solution #2
posted on Nov 01, 2009
Not Rated)
stefanm597
Rating: 85%, 13 votes
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Was this helpful?
Yes
No
Popular Solutions for Amana ABB1927DE Bottom Freezer
Questions and Unsolved Problems for Amana ABB1927DE Bottom Freezer
Do you recommend Amana ABB1927DE Bottom Freezer Refrigerator?
Answer
Answer
the bottom freeer is blowing air not kool..and liaking water with nothing in it..it 7 yurs old?/f
Answer
frig or freezer wont get get cold after movin it from one house to another now?
Answer
I have an Amana frig with the freezer on the bottm. The frig is working fine but the freezer isn't.... (More)
Answer
Freezer handle has de-attached from door on right side - can it be repaired? I cannot see how you... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amana ABB1927DE Bottom Freezer...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
