Question about Microwave Ovens
Microwave my microwave will run but will not heat. bull@carolina.net
  • 579 Answers
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Posted on Jan 03, 2008
How do I change the temperature settings
Microwave ovens don't have temperature settings since they don't cook by applying heat. They generate heat by using microwaves to make the molecules vibrate and rotate.
You may download a copy of the manual at http://dl.owneriq.net/3/345fab3a-597a-4bf2-98a9-e81988116a6e.pdf
May 26, 2013 | Sanyo Microwave Ovens
Need 800 number to call for service
1-888-923-8482 whirlpool customer service phone number for service appointment
Dec 02, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
Arching and sparking when run empty
microwave should never run empty. the reason is that the microwaves needs to heat something. more info : google - how microwaves heat food?
Dec 26, 2010 | GE JES1851 Microwave Oven
Microwave does not heat
Hi
Thanks for using FixYa. Microwave not heating properly is caused by a power relay going bad, cold solder joint on the board and/or magnetron (this is only if it makes a loud hum/buzz sound). Also the door hooks and the door-release button should be checked. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but doesn't heat
Most likely shorted the transformer for the magnatron,Its expensive to repair and you should consider just replacing the micro.
Jun 01, 2010 | Microwave Ovens
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Runs but won't heat
Does the turn table and interior light come on?
Nov 25, 2008 | GE JVM1870 Microwave Oven
Low voltage
Solution: I assumed the device was in good condition, because heat without problem, then I isolate the failure in between the main breaker and the outlet.
The problem was in the line. (110 volts) not properly grounded and maybe with bad size of diameter wire.
I made a independent power supply only for the microwave including his own breaker.- The problem is over. Thanks.
Nov 17, 2008 | Kenmore 63252 Microwave Oven
Microwave jsut went dead. No power, and there is power at the outlet.
check the fuse inside, watch out with those can capacitors as they can give you a nasty shock. For your protection unplug the microwave and wait 24 hours to let the capacitors discharge, then open and find fuse which is usually near the power supply, check fuse, if dead replace it.
Josh, South Carolina
May 03, 2008 | Whirlpool Microwave Ovens
F-9
Need to know the entire model # on the microwave.
Oct 05, 2007 | Microwave Ovens
Microwave Ovens Logo
100 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
