Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
e73 is an input/output error. Hopefully you are still under warranty. Contact Microsoft at Toll free: (800) 4MY-XBOX or (800) 469-9269. If you are outside of your warranty period, I believe they will still repair it for $99
this is what's known as the red ring of death, it will need to be professionally repaired in order to work properly. check with microsoft to see if your unit is still under warranty at this site: http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
if the unit is no longer under warranty, we'd be more than happy to help out. all of our repairs come with a 90 day warranty that covers the whole console, not just what we fix. we also offer extended warranties at an additional cost.
We can fix this for you. It is the same problem as the 3 red lights. We have fixed several of them with this problem. We are a listed repair service on this site. www.videogamerepairservice.com
$49.99 for one year repair warranty service!!
The cause of E-74 with one red light Error might be overheating of your console
and for avoiding such error in future you need to put your machine at an open
space. Ensure that it is placed near the window or you can also make some
external arrangement for cooling of console such as cooling the machine through
a pedestal fan. But as your Xbox already have E74 with one red light Problem
which can be solved by only repairing it, no other alternative. Either you
can send your Xbox to Microsoft (Please note that microsoft is no longer
providing extended warranty for E74 with one red lightError) and wait for 3-4
weeks. If you don't want to wait for a month, you can also fix E74 with one red
light problem with the help of this DIY Video, the guide will explain step by
step approach to fix the problem. Choice is yours...........
The cause of E-74 with one red light Flashing problem might be overheating of your console and for
some external arrangement for cooling of console such as cooling the
machine through a pedestal fan. But as your Xbox already have E74 Error with one red light Problem which can be solved by only repairing it, no other alternative. Either
you can send your Xbox to Microsoft (Please note that microsoft is no
longer providing extended warranty for E74 with one red lightError) and wait for 3-4
weeks. If you don't want to wait for a month, you can also fix E74 Error with one red light
problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours. .
Repair Xbox 360 - 3 Red Lights James at joystiq fixed his own 360 that was flashing three red lights, which indicates an internal error.
If you have this problem try to fix it yourself before sending the unit in.
1) Remove your hard drive and/or memory units.
2) Run “Initial Setup” under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
It might save your xbox 360 a repair return.
