E-Machines eMachines Desktop PC
Problem for E-Machines eMachines Desktop PC
E520 machine is saying there is no audio output
By abryce1 on Oct 31, 2009
e520 machine is saying there is no audio output device installed.this was ok when last used
Comments:
Nov 03, 2009
- when restart clicked says windows is trying to start the following service on local computer windows audio tries to start-greencursor then stops
Nov 04, 2009
- Sorry I did not mean to be insulting. It was while I was attemting your solution that I realised I could restore the files to a date prior to the Windows up date.The moral is don't update unless you need it. Cheers thanks for trying ABRYCE1
Nov 04, 2009
Nov 06, 2009
- Audio is working fine now thanks Cheers ABRYCE1
Best Solution
posted on Oct 31, 2009
Very Helpful)
sardanadixit
Rank: Wiz
Rating: 83%, 284 votes
This can happen in case the windows Audio service is not starting properly
Try this:
Click Start, select Run, type "services.msc" without the quotes and press Ok. Services window will open up. In that window, select the Windows Audio Service and the status and startup type of the same. In case the startup type is disabled, double click on it and select the startup type as Automatic. After that right click on this service and click Start. In case the Start is greyed out, click on Restart. Now check for the sound.
Please rate the solution in case it worked for you and in case it didn't help, leave a comment so that we may help you further.
Comments:
Nov 04, 2009
- Since you have already rated me lowest, there is no point in helping you further. I was trying to assist only.
Nov 05, 2009
- Thanks for the rating. I also did not mean to be harsh, anyways is the sound okay now or you still facing the same problem?
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for E-Machines eMachines Desktop
Questions and Unsolved Problems for E-Machines eMachines Desktop
Do you recommend E-Machines eMachines Desktop PC?
Answer
Answer
lab wont restart a disk read error accurred ctrl alt del wont work
Answer
connecting altec lansing speakers. 221 amplified speaker system . trying to connect to my compuer.
Answer
Was just curious if there was a way to set my refresh to an auto position, to make it refresh... (More)
Answer
cant get the replay lite box to work does anyone have the secret code?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For E-Machines eMachines Desktop...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
