Microsoft Xbox 360 Console
Xbox 360
shared by 16 users
posted by ndh2004 on Jan 02, 2008
my xbox 360 keeps opening and closing and not reading the disc
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by 1JDV on Oct 14, 2008
My xbox 360 keeps saying that my disc are unplayable i bought fifa 09 the other day and my xbox 360 keeps saying it's unplayable i am getting very annoyed can anyone help me thank
15 Other Users Have The Same Problem
Posted by kaikea on Oct 21, 2008
i have it to!!!
Posted by Guest on Oct 17, 2008
me 2
Posted by Guest on Oct 09, 2008
play bout 30 seconds open
Posted by missilepilot on Aug 20, 2008
wont read the disc just keeps openeing and closing this is the first fault ive had with my xbox now its out of warrenty will microsoft replace the unit for free or will i have to pay for a new one
Posted by PAINKILLER13 on Jul 13, 2008
wont play movie...just keeps saying open and close tray... PAINKILLER
Best Solution
posted on Nov 05, 2008
FixYa! (100)
mayacholna
Rank:Wiz Wiz
Rating: 88%, 12 votes
Try this link www.microsoft.com/Xbox360Console
To find your best solution.
6
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on xbox 360:
I don't want to Accept this solution
Best Solution
posted on Jan 03, 2008
Helpful (85)
Irondragon
Rank:Apprentice Apprentice
Rating: 81%, 7 votes
I only thing that might work is calling microsoft and there send you a box then you ship it to them so they casn fix it.
Thank You!
Solution #3
posted on Nov 12, 2008
Not Rated (0)
jbitwa
Rating: 70%, 2 votes
it could be the dvd drive or the laser. but if the disc has a perfect circle near the lens of the disc. it means its missing information and that disc is completly worthless to you.
Thank You!
Solution #4
posted on Nov 10, 2008
Not Rated (0)
n3zjp
Rating: 78%, 2 votes
Disk unreadable errors, if they occur across multiple games, are usually due to failed dvd drive. There are several components that fail. The laser can fail either in the laser diode sending light to the disk, or in reading the light reflected off the disk. The logic board can also fail.
The main problem with the XBOX 360, with regard to this problem, is that the DVD drive contains firmware that holds a secret encryption key that is matched to the XBOX's main logic board. This means that one cannot just go buy a SATA DVD drive and drop it in the XBOX.
Check to see what drive is installed. There are tools and instructions (Google is your friend) to "read" the drive's encryption key off the flash rom and rewrite the flash and key to a new drive.
One can also look around for a source for the laser unit itself. It is a simple install, be careful of the ribbon cable with doing this. Another fix may be to just swap the logic card off of the faulty drive and install it on a known working drive (of like manufacture).
Last, the laser could just be dirty. The mirror is protected with a sticker but heat may cause this to drop off. A little bit of compressed air might help if this is the case.
Thank You!
Solution #5
posted on Oct 14, 2008
Not Rated (0)
lkjhu
Rank:Master Master
Rating: 70%, 8 votes
Hi Friends,
Xbox has a lot of problems. But one of the main problem is Flashing Red Light problem. I found some thing great for many problem of Xbox. I found a very good site for these problem. For find any solution for the problem of Xbox just Click Here.
For search for Flashing Red Light problem now Click Here. I hope this can help you.
Thank You!
Solution #6
posted on Mar 24, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
this is not a solution .every1 knew that solution call microsoft.
Thank You!
Can you Help with these Video Game Consoles problems?
I checked all the connections. There is sound but no...
red flahsing light
my xbox 360 freezes up . now it want even start.
i bought a 42 in tv and a computer how do I register them,...
How in the heck to I register my new Sony Television I...
15 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 29, 2008
EXACT same thing happened to me!!
Comment by Guest, posted on Apr 21, 2008
evey time i put a game in and close it it keeps opening
Comment by jo-el, posted on Mar 17, 2008
my xbox doesnt read the disks i put disks in it reads for a few secs and just says open tray stupid thing
Comment by Guest, posted on Mar 17, 2008
I was playing COD 4 then I heard an odd sound...  jumped up to rescue the disc and then afterwards the tray would not stay closed... I would pop a disc in or no disc for that matter and the tray would just open up again...  this sux.
Comment by playamaid, posted on Feb 24, 2008
we put a game in, close the door, but it opens back up. Sometimes it will take the game, but makes a loud sound when it tries to read disc.
Comment by Guest, posted on Jan 14, 2008
Console worked well until recently. When i put the disc in, it says reading for a few seconds and then returns to open tray.
Comment by Guest, posted on Jan 03, 2008
Just got the XBox360. Played Rock Band and FIFA '08 successfully last night. Today you put any disk in and it says "Reading" then returns with "Open Tray" -- "Insert a game, DVD or CD".
Comment by semaj146, posted on Jan 03, 2008
were can i send my xbox to get refunded or a new sytem.
my xbox 360 the door keeps opneing and closeing and it seems as if it's haveing trouble reading the disc.
my xbox 360 door keeps opening and closeing and not reading the disc
Loading problems.
Repair Service
Find Video Game Console Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
