not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
spoke to hiltonjug last week about our dayton gas furnace. is he out there. he determined air...
(More)
spoke to hiltonjug last week about our dayton gas furnace. is he out there. he determined air switch was bad and we needed new gas valve. just installed new swith....green light still wont go on in control box when we bypass switch and touch the wires together gree light goes on.
Hi I have a Dayton Furnace model number 4LX60 and was wondering about how to wire the electrical and...
(More)
Hi I have a Dayton Furnace model number 4LX60 and was wondering about how to wire the electrical and the thermostat.
I have an older modelBrent wood heater and I need step by step instructions to safely light the...
(More)
I have an older modelBrent wood heater and I need step by step instructions to safely light the pilot light
burners go out after 8 seconds, fan come on, cycles for three minutes then goes out. led ok light...
(More)
burners go out after 8 seconds, fan come on, cycles for three minutes then goes out. led ok light blinks four times indicating the problem is the pressure switch, but my research indicates that it is more likely a flame rod sensor. Both fans come on and electronic ignition is always successful
