Question about E-Machines eMachines Desktop PC
T4010 100Gb HD
I was able to wipe the hard drive with a program but now the xp disk won't run because it doesn't detect a hd.
    Genius:
  • 1,226 Answers
Try to fixed HDD inside the system some wiring maybe lessen.
If not solve, change the cable connecting the HDD.
if not solve; Try boot the system with windows installation disk.
if still see the problems.
HDD maybe damage
If the the disk is detected;
You should back up your files and install new windows if it is necessary.
Posted on Jan 03, 2008
My Optavision 9500 HD light will not come on when power up, it is not even a year old and doesn't get used often. So what does anyone suggest?
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 25, 2012 | Computers & Internet
Bios reconizes new hd drive but xp pro does not
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 25, 2012 | Hitachi Ultrastar A7K1000 HUA721010KLA330...
HD NOT RECONISED BY COMPUTER
Aug 23, 2012 | Computers & Internet
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
ACER ASPIRE IE 3520P is bought recently. Initially HD was partioned into two, one for windows XP and another for SLC.Now both systems are not working and during the reinstallation process HD is not...
Check the BIOS configuration to see if the hard disk is detected.
If it is not detected then most likely it is faulty. If you can boot up with a DOS disk and run FDISK and if FDISK cannot see the hard drive then it is faulty. Then you need to replace the hard disk.
Dec 03, 2009 | Acer Aspire L100 PC Desktop
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Need to reformat a WD 320gb 7200rpm HD...windows hosing
A memory error is not caused by the hard drive not being wiped, However to wipe this drive formatting it using this command wipes it unconditionally (format C: /s /u)
This will format it at a lower level if you get a memory error check the memmory modules run a program called Pc doctor or amidiag these programs can be found on the internet by using google.com. If this information helped you please use FIXYA as a rating please never use Thanks nice try this will give us experts a bad rap on here and we would not stay around if we keep getting them thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 24, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hello,,where do i locate the hard drive in an older type desktop pc,,and if the HD has a genuine XP installed,,can that HD be nigrated to another pc?
before u locate the hard disk i need u to realize that u shud install a new win Xp on that pc where the Hard disk will ngrated to!!
cuz it will detect new hardwares therefore new drivers needed
the disk is always up of the cdrom player.
plz do rate this post
Dec 12, 2008 | Computers & Internet
Dell Latitude D600 with new Hitachi 30GB Drive Not Recognizing
XP install is not detecting any hard disk.
No jumpers are required for laptops, can only have one hard drive in a laptop.
Check the BIOS for the hard disk configuration, make sure that it is set on Auto (detect).
You may have a faulty hard disk, you can check it by booting up with a floppy DOS boot disk, run fdisk to see if it detects the hard disk, OR connect this hard drive to a USB hard disk adapter and connect it to a working computer's USB port and if it detects it as an external drive the it is OK.
Nov 30, 2008 | Dell Latitude D600 Notebook
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
E-Machines eMachines Desktop PC Logo
63 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
