I have a Toshiba Satellite A215-S7437 and suddenly appear a password at the begin startup. What Can I Do?
Comments:
Nov 06, 2009
- Hi!!! Vogun16
The problem is still there in my Lap-Top can you Help me please : Lap-Top Satellite A215-S7437 and model part number is PSAFGU-00L002. I hop that you can help me .
that is a bios password it is a common problem when bios software isnever updated. it is covered under an exception code i believe. email me your model part number and i will tell you the rest of the process monday. or if you want to do it yourself the pin is located under the ram, it looks like two interlocking E's
take a flathead and press in between the two
Comments:
Nov 07, 2009
- absolutely on different laptops the bios password is reset differently however underneath the ram and under the black plastic you should find an interlocking E3 something that looks like what i just wrote. use a flat blade screw driver and place the tip in the middle shorting the two pins together and hold for 30 seconds. that should reset it if not try one more time. if you are unsure of yourself it is handled under an extended warranty exception.
if you are bold i could walk you through it a bit more directly feel free to email me at vaughns@cssnow.com.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Toshiba Satellite? A215-S4747
my sisters A205-S5804 laptop keeps shutting down but only when it's processing files..If it's idle...
(More)
my sisters A205-S5804 laptop keeps shutting down but only when it's processing files..If it's idle it sits there for hours
A215-S4747, the computer is on, but the screen is blank and we can't get it to work. PLease be...
(More)
A215-S4747, the computer is on, but the screen is blank and we can't get it to work. PLease be something simple. What could be the reason?
Hello, I got a Toshiba A205-S5804, as long as it was used I'd erase all from the hard disk with the...
(More)
Hello, I got a Toshiba A205-S5804, as long as it was used I'd erase all from the hard disk with the recovery disk. The problem know is when I try to run the recovery disk it gives me a message: ERROR 08-064B-000 PARTITION CREATION FAILED And then the computer shut down. Please help me
My web cam will start up and if it doesnt say that it is locked by another program i will see myself...
(More)
My web cam will start up and if it doesnt say that it is locked by another program i will see myself , but its kind of a grainy picture. if i move the screen it will shut off or if i put my finger too close to the camera it will shut off. also i was on windows messenger the other day and it worked fine, now it will not work at all. any idea's???
