2yr old Pioneer pdp-506 50" panel with seperate receiver unit
Unit in stand by,,then if you hit power, green LED lights 1 second then goes out then red LED flashes every second for three seconds then pauses three seconds then flashes three seconds etc. Then will not take a off command ,,must unplug tv then goes into standby again.
  • kricko Jan 04, 2008
    Thanks, unit had defective main power board, replaced . Ok now
  • 319 Answers
Hi Kricko
Your blinking light indicates an internal "board" issue. You should contact Pioneer Customer Service for initial help, but you will most likely need a TV repair shop to replace the part.
Good Luck
Pioneer (800) 421-1404
Posted on Jan 03, 2008
  • 2,427 Answers
YOUR MAIN CONTROLLER IC (processor) is damaged you cant try ressiting it but I'm sure it wont work you need to get it professionally repaird by a qualified technician
  • Rishi Roshan Ali Jan 03, 2008
    factory technicians are expensive but alwayts better, maybe you can find a local technician that is just as good that can do it fater and cheaper
Pioneer PDP-R04U receiver blinking Help!?!
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/ Pull up older posts.
Nov 28, 2013 | Pioneer PDP-4350HD 43 in. Plasma...
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
Tv won't come on...light in corner just blinks red
OK Its your power supply and it can be fixd for free due to a recall.
PLEASE READ BELOW what I found out.
Here's the whole notice:
Important: Free Power Supply Replacement for Certain Pioneer Plasmas
Pioneer is continuing to offer a free, in-home power supply replacement for certain of its second and third generation plasma models listed below for consumers who experience a problem with the original power supply. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded in your home at no charge.
Consumer Plasma Models (12 listed):
PDP-505HD
PDP-503PU
PDP-5030HD
PDP-5031HD
PDP-433PU
PDP-4300
PDP-4310
PDP-4330HD
PRO-800HD
PRO-800HDI
PRO-1000HD
PRO-1000HDI
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
We apologize for any inconvenience, and we thank you for your cooperation.
Apr 02, 2010 | Pioneer PureVision Pro-800HD 43 in. Plasma...
5 rapid red blinks on the LED
Solution for error 1, 5 beeps,
For video data transmission from the Media Receiver to the PDP-434HD
and PDP-504HD-series Plasma Displays, digital signals are used.
Therefore, this unit adopts the HDCP (High-bandwidth Digital Content
Protection) system for copyright
protection. This unit is also provided with a detection switch (TRAP
switch) that will prohibit the unit from being turned on again "if the
upper plate of the unit is accidentally opened," in order to prevent
the panel technology from being leaked out.
The TRAP switch is disabled while the unit is turned off. When
performing internal diagnosis of the PDP, fix the switch to the OFF
position using adhesive tape before turning on the
unit. After servicing, be sure to remove the adhesive tape.
Well you've probably guessed what my next question is......How do i
unlock this receiver?. I'm told that it's simply a matter of keying in
3 buttons of the remote in a defined sequence. I have the service
manual but it doesn't say much about unlocking.
"The next generation of Blu Ray players will be equipped with
powerful explosives that will kill everybody in sight if the unit detects
possible tampering or if someone puts a DVD+R in it." )
( They use a photocell to kill the DVI board if light hits it
(as in the backboard removed). The TV continues to work, but not in
HD.
bypass the Pioneer's switch, or put black tape over the photocell.
Sep 30, 2009 | Televison & Video
Pioneer media receiver won t turn on
If the light on the media reciever doesn't come on then the power supply in that needs to be replaced by a service tech. If you disconnect the 2 cables from the media reciever and the panel and then try to turn on the panel it should light with red and green squares for a few seconds but will turn off as it needs the media reciever to be connected.
Mar 29, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
May 23, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
Sep 18, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Mar 21, 2007 | Pioneer PureVision PDP-5030HD 50 in....
Televison & Video Logo
326 people viewed this question
Top Televison & Video Experts
