Question about Kenwood -TK2100-2140-2160-2200-3100-3130-3131-3140-3160-3200-260-270-272-360-370-372-373 Comp... 2-Way Radio
Install wanting to install Kenwood CD-reciever KDC-135/135cr into 1993 Toyota Camry having trouble with speaker hook up not getting any sound can you help
    Brigadier General:
  • 6,966 Answers
Assuming that Kenwood KDC-135 is fully operational then your only concern would be matching the Kenwood wires to the Camry's wiring.
Most Toyota Camry uses the below wiring scheme. I have taken the liberty of including the corresponding Kenwood wires.
Hope that this be of some help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Jan 03, 2008
6ya staff
SOURCE:
I dont get any sound radio,sirris,or cd
Is there something new that was installed or modified in your car recently, even if it's not related to electronics? (even trailer hitches, running board, etc)
Have you checked if there was a ground leak at each speakers?
Are you using an amplifier other than the one in your kenwood reciever?
May 29, 2013 | Kenwood KDC-MPV622 CD Player
Different or additional harness needed to install a Kenwood kdc 255u radio/cd player in a 2005 Scion XB?
YES.... to prevent cutting of any factory wiring (this use to be the old install method and requires much more time and expense) and potential electrical fires, you can now buy quite cheaply, what is called a Radio adapter harness.
As you wish to install a Kenwood radio to your Toyota Scion, simply buy an adapter loom which has a 2005 Toyota Plug on one end, with a Kenwood plug on the other (this essentially replaces the wiring loom that came with your Kenwood unit).
So, it's that easy .... Plug and Play.
And... if you sell your Toyota and wish to put your old Toyota radio back in, the original radio just plugs back in. PRESTO !
Hope this helps..
Cheers,
Scott
Jan 17, 2013 | Kenwood KDC 255U - radio / CD / MP3 player...
Kenwood kdc-x769.everything works on the deck just fine other than no sound at all-not even static. did a full and proper install into vehicle and cant get anything to come through the speakers-any help or...
you may want to check and make sure none of the speaker wires or speaker terminals are shorting out. it just takes one shorted speaker or speaker wire to shut off the entire audio.
Jul 13, 2010 | Kenwood eXcelon KDC-X769 CD Player
I have a kenwood KDC-S3007 CD reciever and it has no plug. I need to know what the pins are so I can hook up the pos., ground, and speakers up to it. Can you help out please. Thanks
any local car audio store that carries kenwood, or maybe best buy should be able to sell you a wire harness. if not, try pacparts.com.
Mar 16, 2010 | Kenwood KDC-S3007
Kenwood KDC-MP438U reciever installed. No sound in any mode.
if its a newer truck it will most likely have a factory amp u either have to utilize or bypass
Apr 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Pls help me fix the clock on my reciever
hey man i have the kenwood kdc mp528 clock adjust is easy. put reciever in stand by mode. hold the menu button for a couple seconds and a menu will pop up. scroll through till you find clk adjst, do you know how to get mp3 player hooked into this?
Feb 04, 2009 | Kenwood KDC-MP528 CD Player
Kenwood cd kdc 215s
Contact a stereo shop. they should be able to get you an adapter that will interface it with the amp.
Sep 13, 2007 | Kenwood KDC-215S CD Player
Radio Communications Logo
227 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
Jason
Lawrence Oravetz
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
