Ipod nano video 4gb will not work unless plugged into power source
Ordered and ipod nano 4gb from apple for daughter for chiristmas, I initially loaded a minimal amount of music onto it, packed it back up, and then took it back out christmas eve. It would only work when plugged into the computer usb, or icraig radio. as soon as it is disconnected from either, the screen goes black and it will not come back on.
  • 5 more comments
  • motomaniac86 Dec 19, 2008
    I have exactly the same problem. It only works when plugged into a power source. As soon as you unplug it goes blank and can not turn on. Is the battery stuffed ????
  • xfile1 Jan 18, 2009
    I have the same problem. Have charged it up fully according to battery, but will not come on if not plugged into computer.
  • bmadrigal2 Jan 21, 2009
    I too have the same problem. The screen illuminates while plugged in, but once disconnected the screen shows lines, then disappears. Won't wake up.
  • stace1234 Jan 23, 2009
    Hi, I have this problem too (a year later). Did anybody have this solved yet?
  • Anonymous Mar 06, 2009
    I have an ipod video and it does the same thing. It will not work unless it is plugged into the computer through the usb. When I unplug it, the screen goes blank and will not turn on again. I have tried restoring it a couple times to see if that fixes it and it still has the problem.
  • jdunn81 Mar 18, 2009
    ipod nano only works/plays/moves when plugged to computer, once unplugged it freezes. I have restored it and I'v reset it, neither have solved problem. Help!
  • sag56 Mar 29, 2009
    same exact problem...works plugged into wall or into my car power source but otherwise will not work...Best Buy says it's an Apple glitch and check with warranty
If you just bought ist automatically set on off if you hold the play button and the hold button is on off is should turn on. otherwise you can try resetting it by flipping the hol switch from on to off then holding the menu and center button for 5 secons. If that doesn't work you should send it back to Apple for repairs or replacement
Posted on Jan 31, 2009
When you get a new ipod you have to charge it for 5+ hours the first time its turned on. If you don't, then the battery never reaches its full potential and it will only operate on the amount of battery stored during that initial charge. If you turned it on and put a few songs on before placing it back in the box, this would ensure the battery to be near-dead at all times.
Solution: go to apple and tell them you don't know why it wont work; it's thier fault.
Posted on Feb 24, 2010
I had exactly the same problem. How i fixed it was to open the ipod up and dissconnect the clickwheel from the board on the ipod. It is a flexible tanned piece of plastic. I also removed the tanned piece of plastic that connects the screen but dont know if it was necessary. I ended up breaking the screen in the process and had to order another on ebay. Putting the ipod back together was a little challenging and the backing plate does not go right on anymore however I did fix the problem. See http://au.youtube.com/watch?v=Ee3KDxVQKtw
Posted on Feb 04, 2009
  • teddyg2007 Aug 30, 2010
    i had the same problem, but mine started doing it a few weeks after i got it, i just dropped it a few times and it started working again :P
I have an ipod 4gb but my daughter put a code now its looked
the only way to unlock is to restore ipod using itunes
http://support.apple.com/kb/HT1339
Apr 06, 2010 | Apple iPod nano
4GB A1199 not charging... double checked USB port, cable, power source etc... Any way or anyone run diagnostics on iPods?
try restarting it by holding ceter button and menu button for 6 sec.then plug it again..if that doesnt work try a different charger
Apr 01, 2010 | Apple iPod nano
My daughter changed the code to the ipod we just bbought off ebay. is their a way to override it . 4gb apple ipod ...Please someone help!!!!!!!
Try resetting it by holding down the play and centre button for about 5-8 seconds until the apple logo appears on the screen.
Jan 13, 2010 | Apple iPod nano
Just plugged my daughters ipod nano 4gb into computer , which is also set up for my ipod ,the nano has downloaded all of my tunes onto its self . How do I delete all the songs off the nano ? Thanks Phil.
Plug the nano into the PC or Mac and open up itunes and then go to devices and select the nano you will be able to delete or turn off the synching to the nano. Hope this helps.
Dec 27, 2009 | Apple iPod nano
My daughter locked my ipod nano 2gb and i cant unlock it can u help
put in dfu mode and plug into itunes and restore
Sep 09, 2009 | Apple iPod nano
Need the unlock code for my ipod nano 4gb
I hate when this happened to me.. only way to use your ipod is to restore it using Itunes
Jun 07, 2009 | Apple iPod nano
I forgot my numbers to unlock my ipod 4gb-grey,and need to know
You will have to plug your Ipod into Itunes and restore it to factory settings in order to reset it. Then reload your songs.
Jan 11, 2009 | Apple iPod nano
Ipod nano 4gb
When i open my Apple IPod, screen turns to initiation mode and does not open. My PC also does not recognise the USB devise. Kindly help.
Regds,
Rafi
Jun 06, 2008 | Apple iPod nano 3rd Generation
Ipod nano
nope, they don't exchange it, unless they have stopped making the nano, and they are still making them
May 24, 2008 | Apple iPod nano
9,393 people viewed this question
 Grubhead
Grubhead
