This can be caused by a worn sleeve bearing; these are commonly used and while quieter when new, wear out faster than a ball bearing.
It may also be caused by an imbalance of the fan blades caused by dust buildup.
With the unit off and a panel removed so you can access the fan blade, gently try rocking the bladed fore and aft to see if you can feel excessive wear.
This type of motor isn't expensive to replace and likely to be a 'commodity' type that can be bought from various sources.
If in the US, look for Johnstone Supply in the yellow pages under Appliance Parts or on line.
If you have a photo of the motor or bring it into a parts house, they will likely be able to hand you the replacement.
Most of this type of motor is mounted with as few as two screws/nuts and easy to replace.
Was this helpful?
Yes
No
Popular Solutions for Fedders A7DH65B2A Dehumidifier
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit!...
(More)
My Fedders Dehumidifier A7DH45B2A*A-R 45Quart, works great but it leaks from the bottom of the unit! I've checked for cracks in the bucket but its fine and collects water too but the unit still leaks:( Everything else is fine with the unit but this. What is going on here? It worked without any leaks for a couple of years and now this! And how do I fix this problem?
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the...
(More)
The dehumidifier powers up and the fan runs, but no moisture is taken out of the air as the reservoir well stays dry.
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no...
(More)
fan runs but no water is removed from the air. The room humidity display changes (lowers), but no water is accumulating in the tank. I took the back off and no ice is accumulating
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last...
(More)
I have a Fedders A7DH65B2A dehumidifier and it has worked fine for a couple of years. In the last month it shut off and now won't power up. When plugged in, the control panel will not even light up. Seems totally dead. Do you have any adice? Is there a fuse on the unit? Please advise.
