Fuse box location on a 2005 suzuki grand vitara diesel. the electric mirrors and the radio dont work so i assumed it was a fuse. i found a fuse box next to the bttery but it only has a few fuses and relays in it so i assume theres another fuse box somewere but i cnt find it... any ideas on where it might be would be much apprisiated.. thankyou..
The most common reasons a Suzuki Grand Vitara speedometer isn't working are the vehicle speed sensor (VSS), a faulty speedometer, or an electrical issue.
Check fuse Q. Check the contacts in the bulbs. check the operation of the bulbs with a couple of lengths of wire and the battery, or test continuity with a meter. Check the contacts in the connector. Check the earths on the back panel. Check for broken or damages wires.
Fuses and relay Suzuki Grand Vitara 2005-2014
For the Suzuki Grand Vitara 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014 model year. Fuse box location. The fuse box is located under the driver's side of the dashboard.
www.outilsobdfacile.com/...plug-connector-obd/Suzuki-grand-vitara-2 Easily find where your OBD2 port / connector is located in Suzuki Grand Vitara (1997 - 2005) ... OBD connector location for Suzuki Grand Vitara (1997 - 2005).
codes.rennacs.com/Petrol-Engine/Japanese-Korean/Suzuki-Engines.php Suzuki Engines - diagnostic connector locations, with detailed diagrams, text, and pictures of where to find the diagnostic connector in the vehicle.
in the fuse box of all cars. if still stock radio.
the owners manual lost, well buy one?
on my gv the engine bay box, is marked, CIG
and the oper guide, page, says, GIG,RADIO, mirrors.
the manual is 4 bucks
why no just DL it.
posted now, over 100 times here.
in the fuse box.
all fuses are covered in the operators guide, in the glove box.
lost? you should get one, so if one blows,, far from home, and stranded???/
in the box 2, in drivers cab (not engine bay)
use #25
clearly marked Cigar,radio ( clock , mirror , accessory socket )
if radio works, its not the fuse. bad lighter.
hi, usually the fuse for the radio is located on the back of the radio its going to be actually in the back of the radio or it will be an inline fuse running in the live wire coming from the back of the radio.
You will need to remove the radio slightly to gain access to the fuse in the back of it.
Let me know how you get on or if you need further assistance ok
On my 2000 Suzuki Grand Vitara (J20, 2.0, 4-Cyl), It is Located near to the left of your knee, below the Dashboard. You may need a Torch to see it.
It looks just like the one Below:
