Question about Whirlpool MH1150XM Convection/Microwave Oven
Everything works but the heat! Any suggestions?
Everything seems to be working, lights, noise, etc...but it will not heat anything. I tried to boil water...doesn't work. Any thoughts?
  • 2 more comments
  • BahBeJo Jan 16, 2008
    I used this unit about two dozen times and I have the same problem. How do I replace the switch?
  • Anonymous Feb 09, 2008
    I have the Whirlpool MH1150XM Overhood Microwave. It was working yesterday, and today trying to warm my oatmeal, it would not heat my food. I have had it for 2yrs 1mth.
  • Anonymous May 06, 2008
    MH1150XMS4
    Had the same problem after about 2 years (bought new). Tested HV diode and cap, replaced faulty diode. Ran good for about 6 months, but now have the same problem. Is there something that will continue to damage the diode, or do I just have bad luck?
  • Anonymous Aug 10, 2008
    Same problem, everything works but the heat. Purchased new in 2005. Replaced magnetron in May 2008 and now have same problem.
    Master:
  • 619 Answers
Door micro switch open/need to replace / if that open the magnetron will not power no heat will produce.
Posted on Jan 03, 2008
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
Everything works on my microwave but it want heat anything. Lights, Vents, and Fans all work properly. There are no weird noises or anything, whats the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 09, 2010 | Whirlpool WMH1162XVS Microwave Oven
Doesn't heat anything
It sounds like the micro generator has died.
Yes, you should buy a new one as the cost of repair is likely to be high.
Jul 01, 2010 | Amana ACO1860 Microwave Oven
EVERYTHING WORKS ON IT BUT IT WILL NOT HEAT ANYTHING UP
The Magnetron tube is what generates the microwaves that causes the heating.
If it runs but there is no heating then either the tube is bad, the overheat safety is bad, or the controller is bad. The tube and controller are both expensive and I suggest purchasing a new microwave instead of trying to repair it if the microwave is older. If the controller seems to be working for everything else then the tube is probably the culprit. You can take the unit apart (unplug it first!) and remove the magnetron tube and take it to a parts store for replacement. First check the safety (if your unit as one) and make sure it is closed (you'll need to ohm it out with a ohmmeter).
The tube usually goes bad when the oven is run without anything in it or there is a lot of reflective items in the microwave (i.e. metal, foil, etc) . What happens is the microwaves bounce around inside the cooking cabinet and never get absorbed by anything. So they end up bouncing back to the magnetron and heating it. The magnetron has metal in it. The tube then overheats and fails. The better microwaves will have a safety that shuts the magnetron down if it overheats.
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Goldstar MV-1615 Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Won't heat
Do the inside light and turntable come on when you try to cook?
Is it making any unusual noise or is it louder or quieter than normal?
Do you have the model number?
Aug 01, 2008 | Maytag MMV5207A Microwave Oven
Danby microwave not heating
yes the turn table turns, everything works, but no heat.
Jul 02, 2008 | Microwave Ovens
Ge jvm1650wb005
Mar 31, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave not heating.
check magnetron related circuit and replace magneron, check condencer, diode and etc.,
Oct 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XM Convection/Microwave Oven Logo
612 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
