The model you have selected should have a self check feature: when turns off and the
green
power light goes off:
ON THE FRONT OF THE SET PRESS AND HOLD BOTH MENU
AND INPUT(some sets the input is called device) together for at least 5 seconds and then release both buttons.
The
power light should blink a two digit error code: for example: 2 blinks,
a pause and 2 blinks--it will repeat the code about 10 times.
error codes for this set:
1, then 2 no error detected
2, then 1 X-ray protection
2, then 2 short protection
2, then 3 deflection circuit problem
2, then 4 vertical deflection problem
2, then 2 is the most common and easiest to fix.
Let me know what you find and if 2,2 I have detailed instructions for repairing that kind of trouble.
I am here to help people.
SD TECH
Comments:
Oct 31, 2009
- 2-1 can be almost anything in the set causing low or high voltage in the picture tubes etc.
almost anything---someone is going to have to troubleshoot it---not likely to get fixed in the home.
SD TECH
