Question about Philips 9P5034C 50" Rear Projection Television
Magnavox Projection Picture Problem
I have a Magnavox Projection model # 9P5034C101. Powered on tv and the screen stretched out and in a couple of times and made some popping noises. Now the left side of the screen bows down and the top has a bow in it. Tried to adjust convergence and i cant get the blue cross to move behind the white cross. Removed screen to access projectors. After looking down in all 3 it looks like the blue one has bubles in it and no video at all. The red and green have some video and looks ok. Would greatly appreciate any help.
  • oldironhead Jan 03, 2008
    I work in the electricial field and can make needed repairs, just need some guidence. I have minimal experience on tv repair. Are the amps located on the digital convergence board ? Will I have to discharge any high voltage from amps or convergence board before replacement or will they auto discharge ? Where do I purchase the amps ? Any other info on replacing these will be greatly appreciated. ! THANKS FOR ALL THE HELP !
  • makeitsimple May 05, 2008
    I have a Magnavox 9P5034C102. It is showing, but the picture is more orange-like and a kind of foggy. What can I do to solve the problem?
    Genius:
  • 1,153 Answers
Sounds like you may need the convergence amps changed and also resistors in that area and maybe fuses.
Posted on Jan 02, 2008
SCREEN IS HIGHLIGHTED RED, ALL WORDS READ IN RED AND THE PICTURE IS BLURRY ON PHILIPS MAGNAVOX 9P5034C101
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 13, 2010 | Televison & Video
Magnavox tv
try degaussing the screen... if your tv doesnt have that option, here are some ways to achieve that http://www.wikihow.com/Degauss-a-Computer-Monitor
Jan 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
3-d look on words and unclear picture
Go to convergence in the menu. If you colors will not move you need convergence amps. Have professional install
Apr 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Help..... Phillip Magnovox Model 9P5034X101
NOT EXPENSIVE POWER SUPPLY PARTS ARE NEEDED TO BE REPLACED . ONLY A TECH WHO , HAS EXPERIENCE ON THIS TV MODEL AND THE KNOWLEDGE ABOUT THIS PROBLEM ,COULD FIX THE TV RIGHT THE FIRST TIME. OTHERWISE REPLACE POWER DEFLECTION BOARD ,PARTS AVAILABLE AT PARTSTORE OR SIMILAR COMPANIES
Apr 25, 2008 | Philips 9P5034C 50" Rear Projection...
MAGNAVOX 51MP392H/17 CONCAVED PICTURE
There is a mode these set run in that stretches the side so the screen is completely filled, this is so the people do not seem all fat and short, this mode is known as Panoramic, this is one of the screen settings you can choose, I believe your set has a 4X5 or normal mode, 16X9 and maby a 16X9 zoom, the panoramic and maybe one more, find the format button on the remote and cycle through them
Mar 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Phillips model # 9P5034C101 Projection TV picture tube
I have a Philips 50 inch rear projection when I power up I have no sound or picture is it done or fixable?
Feb 13, 2008 | Televison & Video
Distorted picture
tv has red & blue converge problem,tried to fix it with remote by multipoint lining the t,s up didn,t help
Jan 12, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
