Question about Canon C130F Black and White Copier
PC-65 (Canon copier)
I have just installed a second A-30 Black Laser cartridge into my copier. I am getting a wide black smudge through the copy., even when I have no original on the copy plate. Can this be a cleaning issue that can be handled in house or is there a technical problem.
Regards
Pat
  • DAN9545 Nov 07, 2008
    I JUST INSTALLED A NEW CARTRIDGE IN MY PC-20 AND THERE ARE HEAVY BLACK LINES ON 2/3 OF THE PAPER, I LOOKED FOR CARBON BUILDUP BUT DID NOT SEE ANY, ANY SUGGESTIONS
    DAN
    President:
  • 2,072 Answers
A smudge across the copy can be in many different areas.
Some ideas.
The drum cleaner may be the problem as you indicate.
It may be a piece of paper ripped of dragging across the surface of the paper causing the smudge.
Also the fuser roll coating may be very worn and causing that.
One thing to try that can show you if the defect is on the drum cartridge, is start to run a copy, After the paper feeds and this is timing, shut the machine off when you think the paper should be about half way through the copy cycle, then see if the copy defect is on the unfused page, If it is smeared before it reaches the fuser, it is in the cleaning section, if it is not smudged, then it is most likely the fuser rollers are needing replaced.
First look for a paper fragment in the path, step 2 is to shut the machine down in mid copy and see if the defect is there.
The fuser is the hot area of the machine in the exit area, If you can take a flash light and look in there and see if you observe wear or heavy toner buildup on a roller then obviously thats the problem.
Posted on Jan 03, 2008
Black spots on each page
A laser printer has its rollers (which I believe you said you cleaned...very important) and the cartridge you put in the printer has rollers too! Carefully check them and the wiper on the cartridge. If all of those things are clean, then you should get clean copy!
Jan 11, 2013 | Dell 3130cn Color Laser Printer
Just replaced black cartridge in my 2600n color laser. I have smudged about a half inch wide 2/3rds over the right of each page. It only smudges in black. I have recalibrated several times. Printed at...
If this just started after you replaced the toner cartridge, one would have to say that it is a bad toner cartridge.
Print something that smudges. Pull down the front cover and look at the cartridges. Pay attention to the top one(black).
Look at the drum on that cartridge. You should see the toner sitting there. Compare it to the other cartridges which should be clean.
Feb 08, 2011 | HP Color LaserJet 2600n Printer
Black smudge on middle of each copy
defective toner cartridge. Replace it.
Please rate solution :)
May 26, 2009 | Office Equipment & Supplies
Canon ImageClass D660
With a clean cloth and maybe a little rubbing alcohol should do
Jul 25, 2008 | Canon imageCLASS D660 All-In-One Laser...
printhead needs to be cleaned and so does the black roller that the paper is printed onto.
Jul 24, 2008 | Canon imageCLASS D660 All-In-One Laser...
Canon pc-6RE copier
check the drum for toner leaking, sounds like the drum blade.
the drum is a shiny cylinder inside the machine, open and and see if it has black rings
Jul 18, 2008 | Canon IMAGERUNNER 6570 Copier
Canon PC941 Copier: Wide white bar down middle of copies
Try replaceing the cartridge the toner has run out.
Any problems please get back to me.
Thank You
Mar 25, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 copier
sounds like white out on the scanner. clean all glass and slit glass
Jan 24, 2008 | Canon PC-940 Black and White Copier
Actually a Canon PC-65, problem follow-up
canon older model PC_6RE problem: the third copy and byond, streeks appear on the left side, progreesivly get worse on each additional copy, a wait of about 2,hours, then the 1st copy is clear again, any solution for this?
Jan 03, 2008 | Canon C130F Black and White Copier
Canon C130F Black and White Copier Logo
239 people viewed this question
old marine
old marine
