Question about Radio Shack Cinego D-1000 Multimedia Projector
Flashing LInes across my screen...
This problem just started a few weeks ago out of nowhere. When i change the projector to my input source (direct tv) it gets lots of flashing horizontal lines across the screen that make veiwing almost impossible. Ive checked all the cable connections and they appear to be fine. Ive also installed several interference blockers to no avail. The problem came out of nowhere and i cannot figure it outl.
ANy suggestions??
  • 167 Answers
Have it looked at immediately before more chaos happens
Posted on Jan 26, 2008
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
Vertical Lines on my Mitsubishi WS-65819
This sounds like a bad connection or a bad capacitor in the 220 volt source that supplies the voltage for the CRT boards. You will need to get a schematic and trace out this voltage from the PM board to the CRT driver boards when the set acts up. it could even be a connection on one of the plugs from the PM board to the CRT boards. Sorry but not a real easy repair. Might take some time to trace unless a component is failing. Good Luck
Jun 29, 2007 | Mitsubishi WS-65819 TV
Projector powers up as normal, bulb comes on, displays Optoma logo on screen and menu will show on screen. The issue is that although I have 3 devices plugged into the HDMI port of the device using a HDMI...
There is a source lock and source button I would unlock source lock button and the push source button until you get to your hdmi input you are using. You also may just plug in one input first and once you get the input right play with the multiple hdmis
Aug 11, 2011 | Optoma HD20 DLP Projector
I have a Optoma EP721. It now projects verticle lines on the screen background. How do you eliminate the verticle lines ?
It sounds like you have a projector which is in need of professional repair. You should eliminate source material problems first though by checking the projector with alternative input sources, ensuring that you also check the cables, and various inputs on the projector.
If the lines are present on all the inputs then the fault is internal to the projector. This will require professional repair. The first point of contact should be Optoma at (UK) or (USA). They should be able to give you an idea of ow much it may potentially cost to have your projector repaired and (most importantly) check whether it is under warranty. Most Optoma projectors ship with 3 year warranties these days.
Feb 19, 2011 | Optoma EP721 Projector
I have a Sony Big Screen Projection TV
unless you work on t.v.s this is nothing you can service.check your warranty &/or call a qualified service tech.hope this helps
Nov 15, 2008 | Sony KP-57WS500 57" Rear Projection...
Wobbly lines on my Toshiba TW56X81
This sounds like a input problem. The source of the signal may not be well matched to the expected input spec. To test, see if the "SETUP" menu items are clear. If so it is something to do with a cable, connector, or configuration of the source.
Mar 12, 2008 | Toshiba TW56X81 56" Rear Projection...
Proxima Ultralight x350 no valid input source error?
reset the settings to factory default. if that doesn't work, the lamp may not have enough power to stay on. if the lamp doesn't have many hours on it, it's the ballast.
Jan 05, 2008 | InFocus Proxima UltraLight SP1 Multimedia...
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
171 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
xxxxxx xxx
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
