Question about Fujitsu AMILO M-6100 Notebook
My laptop amilo m-6100 wont start up
Mu M-6100 wont start up. Ive been given the laptop, with no battery.
When i plug the ac adaptor into it i get the AC Light light on the laptop.
When i press the on/off button, the following lights illuminate ( Power status, AC In, HDD Access And the CDROM).
The Laptop beeps about 5 times and the stops, with the Power status and the AC Light still on.
Any help would be appreciated.
Thanks In Advance
  • Bestcabby Jan 03, 2008
    Thanks for the effort m8, but ive read around on sites on the web, that laptops WILL power up with just the ac power.
    Cheers m8 anyway
Make an upgrade to your laptop Bios. That may fix your problem
Posted on Apr 17, 2008
  • 3 Answers
Although I never tried it, I dont think you can operate a laptop with no battery, even when its connected to AC.
Posted on Jan 02, 2008
I have an acer aspire 5100 and here recently the
Could be a bad battery and/or charger/AC Adaptor/DC Connector. Try to isolate the problem by removing the battery and then plugging the laptop charger in and starting the pc up. It should boot on the AC adapter alone. If it won't boot on the AC adaptor or it flickers and flashes while on the AC adaptor, I would first suspect the AC adaptor or the DC connector on the laptop (try wiggling the power plug at the PC to try and check the connector). If it behaves while on the AC adaptor without the battery present, I would suspect the battery. Either way, you may have to replace something.
Sep 04, 2014 | Computers & Internet
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
My Acer aspire 5750z wont turn on. I have plugged the AC adaptor in and all I get is a nlue light a the from of the laptop. If I take the battery out adn then plug in the adaptor, I don't get an
I have several starting problems with my Acer Aspire. To start with,my On Switch doesnt work so I removed the strip cover and use a matchstick (the non-red end) to push the round black dot in a small square at the extreme top right- hand corner above the keypad. Sometimes it's my adapter lead which works with other laptops so I figure it must be the laptop connection. I keep wiggling the adapter lead close to the laptop connection and push it in hard. My lead is the rotating kind so I try very hard not to move it once connected. Also because I"ve removed the start cover. I have to softly clean the connectors at the top lefthand side and the right.
Hope one of these things help you and you don't have all three problems as I do.
Jan 04, 2013 | Acer Aspire 5920-6727 Notebook
Flashing AC Adaptor
Is the battery any good? A bad battery will cause erratic operation of adapter/charger.
Jun 10, 2017 | Samsung Kitchen Ranges
My laptop wont turn on. i also doesn't blink 3 times when i press the power button with the ac adapter plugged in. i tried taking off the battery and holding the power button on for 1 minute but that still...
Does the blue light come on at the side where you plug your ac adaptor in? If it does, and your laptop still wont turn on, its likely you have a motherboard failure. Also try this without the battery inside. If the light is not coming on the charger port at the side, then its most definitely your ac adaptor at fault.
Jul 22, 2010 | HP Pavilion dv9700t Notebook PC
Gateway mx7118 laptop will not power on
remove the battery, unplug the power adapter. press power button for 30 sec. then connect the power adaptor. press the power button.
if this didnt work you can contact your laptop's manufaturer to run test for your pc..
you can contact this num: 866-539-3901.
Apr 01, 2010 | Gateway MX7118 Notebook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Ac power doesnt work only in battery mode,adaptor output is ok
sounds like the power connector (where you plug into pc) is going bad. try twisting / wiggling connector. pause for a few seconds between twists to give circuitry chance to reconize power input. sometimes there is a green led that will light up when power adaptor is inserted. you can use that as a reference.
Jun 03, 2009 | Computers & Internet
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Fujitsu AMILO M-6100 Notebook Logo
163 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
