Ruud UPMC036 Air Conditioner
Problem for Ruud UPMC036 Air Conditioner
My goodman gaspack has had two incidents of
By kidillac on Oct 31, 2009
My goodman gaspack has had two incidents of cracked heat exchangerS within 18 months apart. Could something be cAUSING THIS TO HAPPEN?
Solution #1
posted on Oct 31, 2009
Not Rated)
billyvangogh
Rank: Guru  Air Conditioners  Expert
Rating: 89%, 31 votes
Things to watch for when your heat exchanger is cracking....
1.Always kee the filter clean
2.Make sure the return air vents are clean and clear of obstructions
3.Your furnace could be Oversized for your house thereby running too hot.
4.The furnace can be "Overfired" basically burniing more gas and running hotter than it's supposed to be
5.It's always best to have your furnace taking fresh air for combustion from outside...basically you should have 2 pipes on your furnace ..one for Air Intake and the other for Exhaust
6.Sometimes some furnaces have a Bad Design and are prone to failure...Some Goodman have "Rings" basically large rivets that pop...this was a bad design however all the suggestions above should help but may not eliminate your problem
Was this helpful?
Yes
No
Popular Solutions for Ruud UPMC036 Air Conditioner
Questions and Unsolved Problems for Ruud UPMC036 Air Conditioner
Do you recommend Ruud UPMC036 Air Conditioner?
Answer
Answer
where can i buy spare pc boards for muz ga80va
Answer
I am trying to wire a Honeywell Vision pro Th8000 series thermostat onto a Weather king heat pump... (More)
Answer
model s1637 ionic breeze quadra the botton foot broke off when i was cleaning how can i get the part... (More)
Answer
2 red lights flashes after Xbox is on game play maybe two minutes and shut off to two flashing red... (More)
Answer
getting two blinks status model m2al 080a -16bn
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
