Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman 12 volt forced air heater model #4230A lighting instructions
I have a pilot light on but the burner wont start the blower comes on. it worked yesterday i powered it up in the garage. can you tell me what i need to do.
  • hung2low153 Jan 04, 2008
    throw it away and live longer retard
    Scholar:
  • 41 Answers
Sounds like you have a blockage to the main jet. If you have a compressor just blow the jet out from the top and with a bit of luck it will clear it. If not you may need to remove the outer covering and find the pipe to the main jet and again using compressed air just blow it out. Usually not much goes wrong with these apart from blockages every now and then and most of the servicing places just blow them out with compressed air. Just make sure if you remove a pipe you tighten the pipe up properly when re-fitting it. Hope this helps.
Regards
Bryan
Posted on Jan 12, 2008
Pilot and burner light then gas shut off model 7900
How many degrees before it reaches desired temp, does it shut off? A thermostat is designed to shut the furnace off a couple/ few degrees before it reaches set temp. It has what is called a heat anticipater, which shuts the burner down, and lets the blower use the remaining heat from the heat exchanger to bring it up to desired temp making it more efficient. If it is more than a few degrees, replace the thermostat. You can jump out the red and white wires to confirm the faulty thermostat. If by doing this, the furnace never shuts down, until you separate the red and white wires. That confirms a faulty thermostat. Hope this helps someone.
Oct 06, 2014 | Coleman Propane Forced Air Heater...
We have a coleman electronic ignite propane furnace for a mobile home it is not even 3 winters old. Regulator just replaced, tenant ran out of gas. We turned off the power and reset the computer-the...
This furnace should have a diagnostic light that will give you a starting point where to look. It is located on the control board and will blink a code. If you remove the panel with the door switch on it, you will erase the code. Look for a small viewing port that looks on to the circuit board. Once you get the code, look on the wiring diagram for a explaination of the codes.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 24, 2010 | Coleman Propane Forced Air Heater...
Hi~ i have a coleman-evcon heater in a mobile. The heater comes on when the thermosat is turned up to, say 65 from 55, then before the air blown out is even really warm, it shuts off. it runs on propane,...
Jan 13, 2010 | Coleman Propane Forced Air Heater...
My central heat is not heating It still blows
If the room air blower runs but the heat is not working, this is an indication that the heater has stored an error code. Your furnace has a diagnostic light that will blink a code. You should be able to view the LED thru a small viewing port in one of the front panels. If you have to remove a panel to get to it, it may erase the error code. If it does, tape down the door safety switch and cycle the furnace with the panel off. Once you get the error code, look on the wiring diagram for a diagnostic code chart. It may give you a starting point to help you. I am also including some other tips that may help.
Dec 30, 2009 | Coleman Propane Forced Air Heater...
Read the instructions on how to light the pilot but where I need to put the match I am not sure where to direct the flame to. I see the housing for the pilot but not where inside
You noted above it is a Coleman forced air Heater with a electronic ignition? You don't need a match to light the pilot, it lights automatic on a call for heat at the thermostat.If it does not light, then you have other problems. Let me know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Coleman Propane Forced Air Heater...
COLEMAN FURNACE BURNER NOT LIGHTING
There is a thermocouple "wire" that is supposed to be touching the pilot flame.
The thermocouple senses a flame (hot) and allows the heater to operate. If the thermocouple does not sense that the pilot is on, then it will not allow the furnace to operate.
Bend the thermocouple wire (or the pilot tube) so that the pilot flame is touchingg the thermocouple.
That shouls work now.
The air from the fan should not be blowing through the same cxavity that the pilot is in.
If it is, then you may have a leaking furnace whereby carbon monoxide may be seeping into your living quarters.
If the fix above works and the pilot stays on after the heater starts, then there is probably no leak.
Let us know the results ... post a comment or "RATE" this or another expert's solution.
Sep 16, 2009 | Coleman Propane Forced Air Heater...
Coleman space heather,when burners goes on it blow's out
it sound like the pilot is too small which would make the pouf sound pilot could be blocked , it should light with a wow wohumph
sounds silly but it the best way to say it or the burner lights smooth
Feb 07, 2009 | Coleman Propane Forced Air Heater...
Coleman Presidential II mobile home furnace. When burner lights the blower cycles on and off instead of blowing constant through burner cycle.
Is this furnace standing pilot or electronic ignition. If standing pilot i would check furnace filter then the thermastat. To test themostat first turn power off to furnace. Take thermostat off wall and take wires labled R & W and connect them together. If you have electronic ignition I would start with cleaning the flame sensor with steel wool or wire brush.If you have and more questions i will be glad to help.
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Coleman Propane Furnace Good pilot light but feed/ignite main burner
If you have a volt ohm meter take the two leads off the gas valve and ohm out the connection should have resistance for the coil. You said you have 12 volts from the thermostat white and red in the heating mode you should have minimum 26 volts. If you want to check the transformer should have 28 volts. Almost sounding like the transformer is getting weak. You can get parts for a 20 year old unit at any HVAC parts house. Try Washer Specialties here in Wichita Kansas they are on the web. Lowes even carries Transformers. Has to be rated 120 volt primary side secondary side 24 volts and 40 VAC.
Oct 27, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
212 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
