Question about Ducane 455 inch 2 - 3 Burner with rotisserie Grill
Propane Problems My grill uses propane bottles. It is new and worked fine through the first bottle. After I replaced the initial bottle, gas was slow coming out and would not get hot. Then I had no flame. Second bottle was definitely not empty. Bought another bottle (third) thinking I need a spare anyway. This bottle worked the first time. Now, it too is not getting enough gas. My suspicion is that I may have slightly damaged (stripped) ventilator gasket. What do you suggest?
The salesman at ACE Hardware told me I needed a grill tip cleaner. Seems the outflow valve from the tank can get crusted and there is a device called a gril tip cleaner that can help restore the gas flow to a higher level.
Posted on Oct 01, 2008
Bad propane gas bottle - is it possible to get bad gas in new propane bottles?
The supplier's bulk propane tank either is not equipped with a moisture filter in the discharge line or the filter is ineffective.
Feb 06, 2017 | Heating & Cooling
Grill gas will not turn on
Turn on propane bottle very slow, works every time.
May 12, 2012 | Uniflame Grilling
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
Low flow of gas to 1st burner, if second burner is turned on flame goes out. bottle full
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 08, 2010 | Weber Genesis Silver B Grill
My grill would not preheat to proper temperature for several uses.Then it would not light,there was no gas smell from the burners.
Sounds like your propane bottle is empty...or maybe you have a bad regulator. Disconnect your propane bottle and pick it up; if it is very light, you need to get the bottle filled (or exchange it for a full one, depending on the type of bottle you have). If the bottle has plenty of gas, change out your regulator.
Dec 03, 2009 | Grilling
Very little gas getting to burners Full bottle of propane Acts the same way as when the propane bottle is getting empty This grill is only about 6 months old
You either have clogged burners and they need to be cleaned. Clogged inlet line to the burners. (This can come from trash, spiderwebs etc in the connection, kinked line etc.) or the regulator is malfunctioning.
Aug 24, 2009 | Weber Genesis E-310 Gas Grill
Burners will not light
Check to see if the bottle is full or empty ? could be a number of problems . Bottle empty ? bottle wasn't purged properly or you may have spiders that have nested in the propane lines which is a common problem.
Jul 26, 2009 | Grilling
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Ducane 455 inch 2 - 3 Burner with rotisserie Grill Logo
236 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
