Some of my keys stopped working, yet if I press down in the left center under the keyboard then they work,, how do I get them to work all the time?? Replace keyboard??
First have the keyboard connector checked. If it is loose or broken you may be forcing the connection by pressing down on the left center under the keyboard.(Secure or Replace) Broken/damaged circuit can have the same affect. It could be as simple as securing a loose connection or a drop of solder in the right spot.
Broken circuit board different matter. Determine if replacing the keyboard will resolve the issue first. This may save you money in the long run. If the circuit board is broken and part of the main board. (99.9% chance it is) This will be expensive.
Make sure the keyboard is positioned correctly and the frame is not warped.
Without saying, do the simple checks first. May save time and money! :)
try to unplug and replug your keyboard cable, also if you can, try n check your keyboard on some other computer, if same thing happens ther also, they YES my dear, TIME TO BUY A NEW KEYBOARD :)
You have an "open circuit" somewhere inside your keyboard - it could be a bad solder connection or a broken wire. In either case I would recommend a new keyboard.
Was this helpful?
Yes
No
Popular Solutions for HP Pavilion ze2000 PC Notebook
HP ze2000 screen fades to black and nothing brings it back other than restarting by using the on off...
(More)
HP ze2000 screen fades to black and nothing brings it back other than restarting by using the on off button.
Trying to update bios on HP ze2315us Says I cant do it without being logged in as admin. I am logged...
(More)
Trying to update bios on HP ze2315us Says I cant do it without being logged in as admin. I am logged in as admin, tried safe mode, went into bios set up and I have the password for that also, no luck. Tried downloading to desktop and right clicking icon to "run as" still no luck. Also, I got this off ebay and it has a amd sempron M 3000+, but for some reason it has a program in the +/- programs called amd athlon 64 driver? Tried to remove and install driver from hp website for sempron, but it wont install till I delete the other and the other wont delete. Any idea's? Thanks.
