Question about Hoover U5254-900 Vacuum
Fan housing my sweeper was making noises when you turned the brush so i tore it apart and found that the fan and the casing that covers the fan is broken. I can't find parts cause i don't even know what i am looking for. i believe i have a discontinued vacuum as well
    Problem Solver:
  • 9 Answers
Http://www.hoover.com/ will help you find a local repair shop and they can get almost anything Hoover as long as it isn't a crank model.
Posted on Jan 03, 2008
How do I Pull apart a Simplicity Synchrony?
The noise is likely the brush roll or the lower motor fan if you only hear it when you turn on the brush roll. Remove the bottom plate to examine the brush roll, there are screws on the bottom of the vacuum that must be removed so that the top nozzle housing cover can be removed. Remove the screws to take the cover off the nozzle housing from the brushroll to the lower motor so you will be able to inspect the fan in the lower motor. You have a high quality precision vacuum that is not easy to repair without proper training. It may save money and provide better results to have it repaired by a qualified Simplicity or Riccar repair shop.
Jan 23, 2017 | Simplicity Vacuums
How do i get my sweeper apart to change the belt
Usually there are screws at the bottom of the sweepers brush head and further back like a cover. look for these screws. Most belt driven vacuums have screws on the under side at the ends of the brush head.
Nov 02, 2014 | Vacuums
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
May 15, 2014 | Riccar Vacuums
Is there a wrong way to attach the belt and the sweeper?? My Hoover Runabout is making a rubbing noise, like the sweeper is hitting something, and it's real hard to push.
take off the belt . clean any hair from brush roller make sure movement smooth . re position belt and move by hand to make sure roller is not skew , , rubber is riding sideways and causing friction .
Mar 22, 2012 | Hoover Vacuums
Have a power brush and cannot get the brush out to clean. I've taken off the main cover, but the brush is held in by a bracket. I can't take off the main cover as I don't have the right kind of...
I have a Miele STB-205-3 Turbobrush. After opening the brush cover using a quarter, I use a T-7 torx screw driver (shaped like star of David) to remove the main cover that is held by 4 screws.
There are 2 more screws holding the fan housing. After unscrewing them, you can take the whole thing apart and clean it. Make sure you clean all rotating parts as they collect a lot of hair, dust, etc,
Sep 13, 2011 | Miele S251i Plus Bagged Canister Vacuum
My Kirby g3 is making a loud noise and the Fan is stoping to fast
POSSIBLE CAUSES: 1) Sometimes there is a piece of debris in the fan case. (Not likely, but possible) Take the power head, handle and cloth bag off of the Kirby, pick it up and turn it with the fan toward the floor and shake it to see if something falls out.
If there's nothing in there and it still makes the noise, you most likely need to replace the fan/impeller as it is probably cracked or broken. You can sometimes see fan damage by removing the power head, looking into the hole in the front of the Kirby and slowly rotating the fan by using the shaft in front. The damage can't always be seen that way, but if you can't see it, you'll need to take the fan case off so that the whole fan is visible to make sure. I have written complete instructions that should lead you through the whole repair.If neither of these things are found to be the case, check the carbon brushes. I don't have a guide written for this yet, but my switch repair guide (link below) will help you break down the Kirby to get to them. Unscrew both brushes, take them out and look at them. The remaining length of brush will pop out of the holder and if they are shorter than 1/2 inch long, I recommend replacement. (they are not expensive)
Jan 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I need to change my sweeper belt on my Dyson 14 Animal
When turned on and set to sweep the sweeper makes a loud noise like it has something stuck in it but the brush is turning abut not does not have a lot of sucking power. It started the other day when a blanket with tassels got caught and wund up in the brush and sucked up in the sweeper a bit. Tried to pull out while running and came out but made the loud noise. If I take off the brush then it does not make the noise when on. I think it might be the belt grooves are worn and slipping when the sweeper is in the sweeping on mode. Sorry, do not know the technical sweeper terms.
Dec 13, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
SWEEPER STOPPED, WITH A LOUD HUMMING SOUND. THE
Do not turn on again. You have an obstruction in the fan . You will need to remove the motor from the lower housing, dismantle the fan cover and remove the obstruction, possibly replace the fan as well.
The lower housing plate can be removed revealing a set of clamps around the motor hosusing which will in tun release the motor from the base of the vac.
Sep 09, 2009 | Hoover U6630-900 WindTunnel Bagless...
The brush on my dyson ds14 will no move.
Can u turn the brush by hand with the vac off. Sounds like a bushing on the brush is siezed or mabe the belt is worn out and too loose. Try replacing the belt
Jul 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover U5254-900 Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
