Question about Car Audio & Video
Car amplifier manual and diagram
Hi i have a sakyno 1800 watt ca-4060 4 channel mosfet amp which blew some sort of ic or chip it has this following number printed on it p1806 i am looking for a manual or someone that could tell me what this thing do as there are six of them and the one overheated and blew
thank you
fanie
  • Anonymous Feb 10, 2009
    MC FUN K2 car amplifier, same problem with p1806
6ya staff
SOURCE:
Anonymous
  • 631 Answers
SOURCE: california 3600 mosfet discrete 3 ch amplifier 600 watts does not work
It sounds like it's going into protect. To be sure it's not the wiring, disconnect all speaker wires from it. If the light still goes out, check the DC voltage on the B+ and remote terminals. Place the black meter lead on the ground terminal of the amplifier. If the voltage remains above 11 volts as the amp tries to power up, the output transistors are almost certainly shorted causing the amp to go into protect.
Posted on Nov 25, 2007
Anonymous
  • 631 Answers
SOURCE: Nirto bmw-486 Tech Specs
Generally, this type of amp is relatively simple to repair if you're capable of replacing the blown parts. If you can find the web site for Nitro, you may be able to get a schematic. I couldn't find their site.
What troubleshooting have you done?
What parts are blown?
If you need help troubleshooting, I'd need a photo of the inside of the amplifier.
[email protected]
Posted on Jan 14, 2008
Hazardsneon
Andrew Hawkins
  • 100 Answers
SOURCE: amplifier
Actually I meant to post that as a solution instead of a request. Let me know If you would like to know more.
-Andrew Hawkins
Posted on Apr 11, 2008
Anonymous
SOURCE: looking for eclipse 32440 premier amplifier
I got my eclipse amp at www.consumerdepot.com
Posted on Aug 25, 2008
Anonymous
  • 55 Answers
SOURCE: legacy 1800 watt amplifier
HI ...NO, YOU CANT JUST CHANGE THE TRANSISTORS..YOU ARE RIGHT THERE IS MORE TO IT THAN THAT.......
Posted on Feb 22, 2009
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Legacy 1800 watt amplifier
Feb 06, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Amp only runs on 1 channel til it is bridged tried 2 sets of rcas and still the same problem
Either the source isn't moving signal through stereo/both plugs, or the amp is damaged and will need repaired by an amplifier technician.
Jan 14, 2009 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Car Audio & Video Logo
239 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
