Home | Honeywell | CT87B ROUND HEATING&COOLING MECHANICAL THE... | Replaced mercury the...
Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Problem for Honeywell CT87B ROUND HEATING&COOLING MECHANICAL...
Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
By nesao on Oct 31, 2009
We replaced a mercury thermostat with a Honeywell "Heat Only" Round thermostat, Model CT87K, to control a newer in-wall gas furnace. It is a simple 2 wire system, but it will not turn the heater on. The little switches are set for gas. When we touch the two wires together, the heater fires up - no problem. I see a battery, but do not know how to get to it without breaking housing. It's brand new, so I don't think it's the battery. Very maddening problem for something so simple. Any thoughts?
Comments:
Oct 31, 2009
- Thank you for you help! I'm sure you have solved the problem. I'll look for a millivolt thermostat.
Best Solution
posted on Oct 31, 2009
Very Helpful)
billyvangogh
Rank: Guru  Air Conditioners  Expert
Rating: 90%, 25 votes
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Honeywell CT87B ROUND
Questions and Unsolved Problems for Honeywell CT87B ROUND
Do you recommend Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater?
Answer
Answer
Hi There, I have an Ideal Response 120 Combi Boiler. Each day the water pressure falls to 0 on the... (More)
Answer
i have a honeywell T86A2917 thermostat which is the live and which screw goes to ground
Answer
I have a Utica boiler pilot is on. and dont ignight some of the time i here water running through... (More)
Answer
cant get my sunvic thermostat to work on a classic ff340 with a hostmann timer there is 1 grey wire... (More)
Answer
I have a 03 Nissan Altima and the heater works only while the car is in drive and in motion. When in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell CT87B ROUND...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
