posted by Haapy Yogy on Jan 02, 2008
If your receiver has problem >>>>turn on 2 second then shut off by itself >>>
You should check location R141 ,R142 .R148 and R149 Value 1.00 Ohm burn out .....(power supply area) >>> good luck to you
Comment by Haapy Yogy, posted on Jan 02, 2008
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 03, 2008
Turn on 2 second then shut off by itself. I found resistors R141 & R142 in the power supply open just as reported. These resistors are 1 ohm ,1/4 watt fusible resistors. I replaced mine with 1 ohm 1/2 watt fusible resistors to increase reliability. While I had the power supply board out, I also replaced the other 2 resistors also. thanks!!
Suggest a new solution for this problem
Post a New problem for Denon AVR-1601 5.1 Channels Receiver
Email this problem
Email this problem
Can you Help with these Receivers problems?
denon avr 1601 sem som em modo...
Ol?¡ tenho este dito... Answer This...
problem with denon avr 1601
hi guys, when i turn on my avr... Answer This...
Repair Service
Find Receiver Repairman Near You:
