Question about Palm Treo 600 Handheld
Problem Getting My Palm 600 To Recharge
I have allowed my Treo to lose its charge. The light on the charge illuminates but goes out when I connect the Treo. Can you assist me in getting my PDA charged up again?
I may be contacted at:
rsford@sbcglobal.net or rodney_ford@bcbstx.com
Thanks in advance for your assistance.
  • 59 Answers
Try plugging the Treo in to recharge and then at the same time poke the reset hole in the back of it. This should reset the charging mechanism in the Palm. Let it sit for a hour or so and then try powering it back on.
Posted on Jan 04, 2008
320 ml cdi car would not start 4 hours later -20 tempetures all dash lights come on
are you sure that your batterys not dead? when you attempted to start it, did the engine turn over? or did nothing? clicking sound? do headlights come on when you try? if not, then try to boost it from another car with booster cables,when the cables from the other car are connected,allow the booster car to run engine while the cables are connected to your battery for 10minutes before you attempt to start your car. this will allow your battery to build the charge to start your engine. if this does'nt work the first time,allow the battery to charge from the booster car for 15minutes. if this does'nt work,remove your battery and take to an autozone or advance auto parts store.they will charge and check your battery for free! you have nothing to lose. if you do not have the above named stores close to you then, charge your battery with a battery charger.which you can purchase at wal-mart or harbor freight tools,k-mart,or a pawn shop! hope this assists you! you can vote on my assistance if you choose to. either way,i know that i've attempted to assist someone somewhere for free! thank you!
Jan 24, 2011 | 2007 Mercedes-Benz ML320 CDI
WHEN I CHARGE MY TREO 650 THE RED LIGHT AND CHARG...
Charging circuit cause trouble due to heat, please see a technician or first use "restore factory settings"
Regards
Marshal
Dhaka, Bangladesh
bdman2010@hotmail.com
May 20, 2010 | Palm Treo 650 Handheld
Treo 755p screen light goes out
Found my own problem...it WAS under "settings"...under lighting, I believe. Thanks anyway.
Sep 01, 2008 | Palm Treo 755p Smartphone
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Treo 700P Charging issues
I'm assuming you have problems with syncying also. What I do is turn off the Treo, take out the battery, and unplug the the cord from the USB port. With everything unconnected clean the contacts in the treo, on the outside of the treo and the plug on the chord with alcohol on a Q tip. On the battery only clean with a dry cloth, no alcohol.
Put it all back together and see if you get a better connection. If this doesn't work it is probably your battery.
Jun 11, 2008 | Palm Treo 700p Smartphone
Resetting to Power Off
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Mar 07, 2008 | Palm Treo 650 Handheld
Palm treo 700 wx won't charge
Verizon 700wx:I had the same problem. With little or no movement, the phone would go from charging to not over and over. At home with it perfectly still it would charge maybe 1/4 in 6 hours. Same problem with 3 different chargers. With the battery out, I dipped a Q-tip in rubbing alcohol squeeze out excess and jammed it into the charging port on the phone. Put the battery back in and oh **** nothing. Took it back out and let it dry for a few minutes and were back in business. No more charging problems at all.
May be a little risky, but warranty was up and what did I have to lose. Anyway good luck!
Feb 16, 2008 | Palm Treo 650 Handheld
Treo 650 cell phone
buy new battery nimh in ther sit so long loses full charge cant get back .
Feb 05, 2008 | Palm Treo 650 Handheld
Initial charge
Does anyone have an answer to this. Or just return it.
Oct 30, 2007 | Palm (3206WW) Wireless Headset
Music Explorere Software Missing
Hold down the <down arrow> button while plugging in the USB cable and the Treo 15 will automatically start in the Hard Disk mode. Then, you can add or remove software as if it were a hard drive. Works like a charm!! (Be sure to have the power cord attached.)
Nov 06, 2006 | E.Digital Treo 15 MP3 Player
Palm Treo 600 Handheld Logo
54 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
