where is the filter located. old hse was placed ,2 , 20by 21 changable filters on cold air return vent which was hinged, this vent cover is not. the large cold air return is pretty dirty on this system. I can't believe there is no filter ??? Oh , this is a ruud siloutte 1 unit
filter should be beside or inside the furnace fan compartment....if you have an Electronic Air Cleaner (EAC) thyat's working . no other filter is required
solid green led followed by flashing green led which flashes five times before resetting, followed...
(More)
solid green led followed by flashing green led which flashes five times before resetting, followed by a solid red led
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging...
(More)
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging is wire up the low voltage for the heat pump. I can't seem to find out where the wires go from the heat pump. It has 4 wires: Brown
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut...
(More)
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut off. a/c comes on, and get cold, but blows on low. seem like the switch is switched to on, instead of auto.. CVould this be control board? Thanks
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
