Question about Ellion DVR-530S DVD Recorder
Ellion DVR-950S DVD playback suddenly stopped and the indicator light started flashing red/blue combined. None of the buttons on the remote or the machine is working.
  • j_watts Mar 21, 2008
    Yes
    I am experiencing the same issue, only the flashing red/blue power light appeared after tryying to change input to scart. The power started flashing and all controls stopped functioning.
    The Ellion has locked up before, a complete removal of power for a few minutes allowed it to reboot OK. This time it just returns Flashing Red and Blue?
Ellion DVR 950S Festplattenrecorder.
Please help me.
I have a problem, that the Power on/off Display get never out - it is a loop - power on an than power off power on .....
I diconnect the line (power cable), but it is the sam again. There is no more - other funktion by the recorder.
Thank you for help
walter-august
Posted on Jan 13, 2009
Have not been able to get it to work to turn TV on & off and on sound---
Try by set it up with an other set-up code said for your device brand. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list,
use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may
be another code
in the code list that performs more functions. Try other codes from the code list for more functionality.
PROGRAMMING PROCEDURE
Direct Code Entry
Locate the Remote Code List provided in this manual. Find the DEVICE CATEGORY you wish to program (for
example TV, CBL,
DVR, DVD, SAT, AUDIO, AUX1, AUX2) and then find the BRAND of that device. Circle all the codes under that
brand. Example: For a GE TV, locate the TV code section then circle all of the GE TV codes.
Manually turn on the device you wish to control.
Press and hold the SETUP button until the red indicator light stays on (approximately 2 seconds) and then release
the SETUP button.
Press and release the desired device button on the remote (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2). The
red indicator will blink
once and then remain on.
Enter the first 4-digit code previously found in the code list using the number buttons on the remote. If the code
entered is a valid code, the
red indicator light will turn off. If the code entered is not a valid code, the red indicator light will flash and remain on
allowing you to re-enter the code.
[If no buttons are pressed for 35 seconds, the remote will exit the SETUP mode and you will have to start over.]
Point the remote at the device. Press the POWER button, if the device turns off, no further programming is required
for that device. If the device does not turn off, return to step 3 and use the next code found in the code list. Continue
this process until a code for your device is found.
To view a helpful demonstration video for programming your ONN remote, see QR code.
• You can use any device button to control other devices in your home entertainment system. For example, you can
use the AUX1 device
button to control an audio receiver or a DVD, VCR, satellite, etc.
• For combination devices, you may have to enter a code for each device. For example, for a VCR/DVD device, you
may have to enter a
code for the DVD under the DVD button and enter a code for the VCR using a different device button on the remote.
• Write down the code found to operate your device for future reference.
Auto Code Search
The Auto Code Search searches automatically through all of the codes stored in this remote. Read all the following
steps prior to starting the auto code search as you will need to be prepared to lock-in the proper code when found.
1.Manually turn on the device you wish to control.
2. Press and hold the SETUP button until the red indicator light stays on (approximately 2 seconds) and then release
the button.
3. Press and release the desired device button on the remote (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2).
The red indicator will blink once and then remain on.
4. Point the remote at the device and press and release the POWER button (for TV) or PLAY button (for DVD, VCR,
etc.) to start the search. The red indicator will flash (approximately every 2 seconds) as the remote searches. Note:
The remote must be pointed at the device for the duration of this search.
5. Place your finger on the #1 button so you are prepared to lock-in the code.
6. When the device shuts off or begins playing, press the #1 button to lock-in the code. The red indicator light will turn
off. Note: You have
approximately two seconds after the device shuts off or begins playing to lock-in the code.
7. Point the remote at the device and check to see if the remote operates the device as desired. If it does, no further
programming is required for that device. If it does not, return to step 2 and start the auto search.
• This process may take several minutes as the remote contains many codes.
• The SETUP button can be used during the search process to reverse the direction of the search of the remote
codes. For example, if you miss the code for your device and the remote is continuing to search (as indicated by the
blinking red light), press the SETUP button and the code search will reverse direction and return to the code.
• When using the Auto Code Search programming method, the device button corresponding to the type of device you
want to control must be selected (for example, the TV device button must be selected in step 3 if you want to control
a TV, the DVD/VCR device button for a DVD player, etc.)
be another code in the code list that performs more functions. Continue the code search as directed above until the
best code is found.
Controlling Combo Devices
Some Combo devices (e.g. TV/VCR, TV/DVD, DVD/VCR, etc.) will require you to setup up two different Mode
buttons to control both parts of the Combo device. For example, if you have a TV/DVD Combo, you might need to set
up one code under the TV button to control the TV part AND a separate code (under any other Mode button) to
control the DVD part.
Master Volume Feature
The Master Volume Feature allows you to select a single device (TV or audio receiver) that the volume control
always controls. For example, the remote can be in TV mode while the volume buttons control the volume on your
audio receiver instead of your TV.
Enabling the Master Volume Feature
Press and hold the SETUP button until the red indicator stays on (approximately 4 seconds) and then release the
button.
2. Press and release desired device button (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2) for the device you
wish to setup to control
the volume.
3. Press and release the MUTE button.
4. Press and release the VOL + button. The red indicator will blink twice and then go off. To test the feature put the
remote in another mode such as the TV mode if you programmed the audio receiver to be the Master Volume
Device. Point the remote at the audio receiver,
press and hold either the VOL + or the VOL - button. If the audio receiver volume changes then the remote is
programmed correctly. If the TV volume changes and not the audio receiver, you will have to repeat the steps above
and test again.
Disabling the Master Volume Feature
Press and hold the SETUP button until the red indicator stays on (approximately 2 seconds) and then release the
button.
2. Press and release the device button (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2) which is programmed to
control the Master Volume Feature.
4. Press and release the VOL - button. The red indicator light will blink twice and go off. To make sure the Master
Volume Feature is disabled, put the remote in TV mode if you programmed the audio receiver to be the Master
Volume Device. Point the remote at the TV and
press a volume button. If the volume changes on the TV, the feature is disabled. If the volume on the audio receiver
changes, and not the TV, you will have to repeat the steps above and test again.
Reset to Factory Settings
button.
2. Press and release the MUTE button.
3. Press and release the number #0 button. The red indicator light will flash twice.
Remote does not operate your device.
• Make sure the batteries are fresh and installed correctly.
• Aim the remote directly at your device, and make sure that there are no obstructions between the remote and
device.
• Make sure you select the appropriate device on the remote you wish to control, for example, TV for TV, DVD for
DVD, etc.
• Try programming the remote with a different code. See Direct Code Entry section.
• Remote may not be compatible with your device.
Remote does not operate some features of your device.
• Sometimes a particular code might operate a few features but not all. Try programming remote with a different code
from the code list.
• Remote may not be able to operate all features of your device or button names may be different than that of your
original remotes.
Remote Code is not available for a combo device (e.g. TV/VCR, TV/DVD)
• Some Combo devices (e.g. TV/VCR, TV/DVD, DVD/VCR, etc.) will require you to set up two different Mode buttons
to control both parts of the Combo device, For example, if you have a TV/DVD Combo, you might need to set up one
code under the TV button to control the TV part AND a separate code (under any other Mode button) to control the
DVD part.
Jan 06, 2016 | JVC Remote Control 118579 6.0 p/n:118579
Tip
CODES FOR BLUE RAY AND DVD
DIRECT CODE ENTRY
1.Locate the Remote Code List [ link bellow ] provided in this manual. Circle all the codes under that brand. Example: For a GE TV, locate the TV code section then circle all of the GE TV codes.
2. Manually turn on the device you wish to control.
3. Press and hold the SETUP button until the red indicator light stays on (approximately 4 seconds) and then release the SETUP button.
4. Press and release the desired device button on the remote (TV, DVD, CBL/ SAT, DVR/AUX). The red indicator will blink once and then remain on.
5. Enter the fist 4-digit code previously found in the code list using the number buttons on the remote. If the code entered is a valid code, the red indicator light will turn off. If the code entered is not a valid code, the red indicator light will flsh and remain on allowing you to re-enter the code.
Note: If no buttons are pressed for 10 seconds, the remote will exit the SETUP mode and you will have to start over.
6. Point the remote at the device. Press the POWER button-if the device turns off, no further programming is required for that device. If the device
does not turn off, return to step 3 and use the next code found in the code list. Continue this process until a code for your device is found.
7. Repeat this process for each device (for example TV, DVD, CBL, SAT, DVR, AUX) in your home entertainment system you wish to control. Four devices can be programmed.
PROGRAMMING NOTES FOR DIRECT CODE ENTRY
#If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
# Sometimes the fist code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
# With the Direct Code Entry method, you can program any device button to control any device in your home entertainment system.
For example, you can use the DVR/AUX device button to control an audio receiver or a DVD, VCR, satellite device, etc.
# For combination devices, you may have to enter a code for each device. For example, for a VCR/DVdevice, you may have to enter a code for the DVunder the DVD button and enter a code for the VCR using a different device button on the remote.
# Write down the code found to operate your device for future reference.
Codes
Electronics Equipment Repair Center
on Jan 28, 2015 | General Electric Universal Remote Control
I have a Sony BDP S370 and I would like to make it region free for my DVDs.
hi,
u can make your dvd for region free DVD play back. but for that you have to purchase an universal remote (ONE FOR ALL URC-7950). through this remote only you can make player DVD region free.
first of all u have to set( program) the remote for the same purpose.
Full procedure for the OneForAll URC-7950 remote is as follows:(preparing remote)
1. Press DVD
2. Hold the magic button until the Power key flashes twice.
3. Press 0533
4. Hold the magic button until the red led flashes twice.
5. Press 994
6. Press Magic key (don't hold)
7. Press 00189
8. Press 1 ( this sets it to key 1 - it flashes twice, if not repeat steps 4 to 8 )
9. Hold the magic button until the red led flashes twice.
10. Press 994
11. Press Magic Key (don't hold)
12. Press 00255
13. Press 2 ( this sets it to key 2 - it flashes twice )
14. Hold the magic button until the red led flashes twice.
15. Press 994
16. Press Magic Key (don't hold)
17. Press 00095
18. Press 3 ( this sets it to key 3 - it flashes twice )
19. Hold the magic button until the red led flashes twice.
20. Press 994
21. Press Magic Key (don't hold)
22. Press 00221
23. Press 4 ( this sets it to key 4 - it flashes twice )
24. Hold the magic button until the red led flashes twice.
25. Press 994
26. Press Magic Key (don't hold)
27. Press 00079
28. Press 5 ( this sets it to key 5 - it flashes twice )
The remote is now programmed and ready to use, to make the BDP-S370 region free
1. Use the remote that came with the player to bring the player out of standby, make sure there isn't a disc in it.
2. Press 1, 2, 3, 4, 5 on the OneForAll URC-7950 remote. The power light will start flashing. (blue middle light)
3. Put the player back into standby with the Sony remote.
4. Next time you turn on the player it will be region free for DVD playback.
OK
Jan 13, 2011 | Sony BDPS370 BluRay Player
How to unlock region free on U.S sony bdp-s350
Sony BDP S350 bluray - unlocking to region free Yes, it is possible, but you'll need a programmable remote - most use the "one for 3/4/6/all". You can hack it by using the same code as for the bdp-s350. Follow the instructions exactly and it should work - mine does.
Programming the 7040 OneforAll remote to enable region free playback of DVD's on the Sony BDP-S350 Quote: 1. Press DVD 2. Hold the magic button until the DVD button flashes twice. 3. Press 0533 4. Hold the magic button until the DVD button flashes twice. 5. Press 994 6. Press Magic Key (don't hold) 7. Press 1891 (this sets key 1 - the DVD button flashes twice) 8. Hold the magic button until the DVD button flashes twice. 9. Press 994 10. Press Magic Key (don't hold) 11. Press 2552 (this sets key 2 - the DVD button flashes twice) 12. Hold the magic button until the DVD button flashes twice. 13. Press 994 14. Press Magic Key (don't hold) 15. Press 0953 (this sets key 3 - the DVD button flashes twice) 16. Hold the magic button until the DVD button flashes twice. 17. Press 994 18. Press Magic Key (don't hold) 19. Press 2214 (this sets key 4 - the DVD button flashes twice) 20. Hold the magic button until the DVD button flashes twice. . 21. Press 994 22. Press Magic Key (don't hold) 23. Press 0795 (this sets key 5 - the DVD button flashes twice) Done - the remote is now programmed and ready to use Quote: 1. Now to make your player region free use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed 2. Make sure there isn't a disc in the machine. 3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing) 4. Put the player back into standby with the Sony remote 5. That's it, the next time you turn on the player it will be region free for DVD playback If the blue 24p light doesn't flash then it hasn't worked, try a new set of batteries and start a fresh Good luck
Dec 02, 2010 | Sony BDP-S350 Blu-Ray Player
TV doesn't turn on - red lindicator light is just flashing
check and replace your horizontal output transistor as well as the regulator..
May 17, 2010 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
I HAVE A NEW SONY BDP-360 SONY BLU-RAY PLAYER AND I HAVE A DVD FROM AMERICA I CAN'T PLAY AS WE ARE IN REGION 2 AND IT IS REGION 1. ANY WAY OF DE CODING THIS SO IT CAN PLAY ALL REGION CODES. THANKS.
Yes there is a hack to make the DVD region free, as far as I know there is not one for the Blu-Ray as yet.
You will need your original remote and a 7040 OneforAll remote to enable region free playback of DVD’s on the Sony BDP-S350.
Programming the 7040 OneforAll remote.
1. Press DVD
3. Press 0533
5. Press 994
7. Press 1891 (this sets key 1 – the DVD button flashes twice)
9. Press 994
11. Press 2552 (this sets key 2 – the DVD button flashes twice)
13. Press 994
15. Press 0953 (this sets key 3 – the DVD button flashes twice)
17. Press 994
19. Press 2214 (this sets key 4 – the DVD button flashes twice)
21. Press 994
23. Press 0795 (this sets key 5 – the DVD button flashes twice)
5. That’s it, the next time you turn on the player it will be region free for DVD playback
If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
Good luck.
Jan 23, 2010 | Sony BDP-S360 DVD Player
REMOTE CONTROL FOR ELLION DVR-950H HAS STOPPED WORKING, NEW BATTERIES DID NOT SOLVE PROBLEM, ANY SUGGESTIONS
Can I make an offer to the people with remote control problems?
I recently bought two Ellion DVR-960E from an auction.
They both came complete with remote controls.
Unfortunately only one of the machines did not but luckily enough the other one worked perfectly along with both remote controls.
The downside is I do not have the instruction manual so I'm not sure how all the fuctions work.
I contacted Ellion but 1 month later I have heard nothing.
Therefore I thought we could help each other.
If someone could scan then email me the instruction manual.
I would in return send you my spare remote control.
I would post in a padded envelope and pay the £1 postage.
If anyone can help please email me at:
sealisdamaged@yahoo.co.uk
Aug 27, 2008 | Televison & Video
Locked tv
MY TV IS LOCKED CANNOT GET IT TO TURN ON HELP!!!!!
May 03, 2008 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Ellion DVR-530S DVD Recorder Logo
405 people viewed this question
Top Ellion Televison & Video Experts
Marvin
Marvin
Are you an Ellion Televison and Video Expert? Answer questions, earn points and help others
