Vacuums
Generic problem for all Vacuums
Power Issue
shared by 2 users
posted by tmaccallum on Jan 02, 2008
Hi...my Miele vacuum cleaner (S314) will not turn on, unless I lean it on its side (the side that the power switch is on). I took it apart and the wires are all well attached, and I do not see any issues with the connectors. Is this a common problem with an easy fix?
Thanks!
Todd
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by DSteinbach on Sep 09, 2008
My Miele vacuum cleaner (S314) wont turn on either. Have taken it apart, and trying to diagnose the problem. No burnt marks to indicate overheating. Will look at the cord reel contacts and see if they can be cleaned or bent to make better contacts.
Called tech support at Miele, and was told to look between the cord reel and the board, and if it wasn't there, to look at the board. The board only looks like it is 3" x 3". No solution yet. Dave
Solution #1
posted on Jan 15, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1324 votes
Could be the cord reel causing the problem. Sometimes the contacks on the inside of the reel loose contact and won't conduct. If this is the problem, then you will have to replace the reel cord asm. Part # 06777540, may cost about $150 approx.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Power Issue:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Hoover SteamVac F5914-900 SpinScrub Upright...
I just assembled my F5914-900 Cleaner, and I can't get the...
Vacuums
Need how in removing the motor.
Dyson DC07 Bagless Upright Cyclonic Vacuum
old belt snapped had a look underneath ,took guard off but...
Hoover F5881-900 Vacuum
Should the flexible 10-12 inch hose behind the used...
Hoover F6212-900 / F6215-900 SteamVac...
would like to know how to repair it.I need step by step...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
