Question about Nakamichi SoundSpace 8.5 System
My SS 8.5 won't power up...It WAS working just fine...
...Now it won't turn on. I have checked power cables, all of the switches, etc. Any help would be appreciated. Are there any fuses I can check?
Thanks in advance,
Martin
  • 3 more comments
  • fuwt Feb 04, 2008
    I have exactly the same problem.
  • khil007adi Mar 15, 2008
    The same happened to me just now; I was watching a DVD and all of a sudden there was a low pop (like when you hear a sub give a bad sound) and now nothing would turn on. I tried to unplug everything and plug it back in and still nothing.
  • fplkev Sep 29, 2008
    Same problem. I changed the batteries on the remote - no help. I then physically pushed in the "ON" button on the receiver - nothing. The only thing I noticed at the time was that both the receiver and the amplifier seemed a bit hot - particularly odd since neither had been on since the evening before and both are well ventilated.
    I will look for a fuse as suggested here. Otherwise, where can I get it serviced?
    Thanks
  • juangramos Jan 05, 2009
    I check cables, electricity, and the unit only blink the orange led on the center amp.
  • rmturner0605 Feb 10, 2009
    Fuse in the amplifier unit? When I power on the amplifier with nothing
    else connected, the orange light comes on indicating it has power. When I go to connect the data cable to the
    receiver, the light goes out (when functioning properly, it turns blue).
  • 4 Answers
HI.
these nak units are kind of fussy. First check the main pin connection cable that goes from you control unit to the sub. Sometimes they get loose or the pins become misaligned. This will cause the system to become inoperable. Also, check the fuse on the sub unit. On my ss8 (not 8.5) there is a fuse inside the sub/amp box. just unscrew the cover plate and you will find it there. You can buy a replacement at radio shack for a couple bucks.
Posted on Sep 15, 2008
6ya staff
SOURCE:
Power will not come on when ignition is turned to start
Hi, Steve and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty kickstand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
What to do When Your Motorcycle Won Start
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
TROUBLE SHOOTING
troubleshoot motorcycle not starting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 28, 2016 | Power Motorcycles
When I try to start my spyder sts-se5 I turn the switch and nothing happening, its as if their is no power, no light or nothing. Can you help?
Hi, Sarah and the usual suspects are:
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
6. Faulty jiffy stand or clutch pull in switch/sensor.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.
Spyder won start Can Am Spyder Forums The factor Community
Thread Won Start won turn over
2014 CanAm Spyder RT Series Repair Maintenance Parts Master Collection...
Can Am OEM Parts
http://www.spyderlovers.com/RT/NEW2010RT.pdf
Sep 15, 2013 | CanAm Motorcycles
1995 Ducati 750 ss wont start
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
1999 750SS engine turns over but won start Ducati ms The Ultimate Ducati...
Ducati won start Biker ie Forums
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Jan 10, 2013 | 2002 Ducati 750 SS
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
2002 Yamaha XN Teos 125 will not turn over
Hi, David before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters Scooter won start
TEOS 125 150 2000 pdf
OEM parts for Yamaha
Yamaha TEO XN125 Owner Manual
Aug 09, 2017 | Yamaha Motorcycles
2000 750 ss have lites but no power to the starter selniod or fuel pump or spark each one tests out what may be problem? is it a relay maybe my ecu thanks dave
Hi, Bikerdad1368 and the usual suspects are:
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
ducati 900ss no spark
Ducati Maintenance
Oct 14, 2010 | 2000 Ducati 750 SS i.e. N-C
Ducati 900 ss turns over won't start?
Hi, Ab_brown and the usual suspects are:
1. Fuel tank empty.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
92 Ducati 900ss Won start
Ducati Maintenance
Jun 01, 2010 | 2001 Ducati 900 SS i.e. N-C
Kitchenaid 24" SS dishwasher
the first thing to check is power. check your breakers to see if any are tripped. if so turn it off than on some breakers do not reset if you just switch them to the on position. also check if it has a plug or shut off switch in a cabinet nearby .
Dec 31, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Nakamichi SoundSpace 8.5 System Logo
277 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
