I have a ariston margherita A1635 washing mashine, the problem i have is that the programme selector knob keeps turning when the wash cycle gets to drain and spin, we have to reset as per the manuale, but this does not always respond , we have to switch off the mashine and leve for a while then re set and start again, it will ok for a few washers the do this silly thing again, it there any think that can be done before i call out an engineer. thanks
HI, The boiler shows E34 error code, when the plank is removed its working as normal and when...
(More)
HI, The boiler shows E34 error code, when the plank is removed its working as normal and when re-fixed it shows the code again.
Ariston Gas Boiler error code E02 what is the problem. No other boiler specification on the type of...
(More)
Ariston Gas Boiler error code E02 what is the problem. No other boiler specification on the type of boiler.
I had an Ariston range hood which got brittle and then broke apart.It was 60cm wide and I would like...
(More)
I had an Ariston range hood which got brittle and then broke apart.It was 60cm wide and I would like to know which range hoods will last longer than 5 years,and fit into the same space as the Ariston.
