Question about Sony PlayStation Portable (PSP) Console
Playstation hook up
Hi, i have a playstation outfit. It is not a 1 or 2. I just need to hook it up to a television so my 9 year old can use it. The playstation has 3 lines coming out,green ,red and white.The television has two inputs on the front.One white one yellow.Thanks Audrey
    Sergeant:
  • 310 Answers
Hi Audrey, you need to get some a av cable ie the av with the 3 av connections on both ends, then i would buy a av - skart adapter so it will plug into any tv, i would say for both around £10 for both.
and it will get you up and going..
All the best
John
Posted on Jan 02, 2008
Hi i´m having trouble with
mabey you could get a professional to fix it,from jade a 9 year old girl from jamestown.
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
Before going to Florida, I used my playstation on my KP-51hw40, and had an amazing picture. I took my playstation out of town and used an old TV to play. When i came back into town and hooked it up to my...
it sounds like the playstation is still set for 480i. do you have it hooked up composite? (one yellow vid cable) that could be your problem, ps3 optimal with component(red green blue vid wires) or HDMI, then make sure your settings are saving properly on your unit
Mar 18, 2010 | Sony KP-51HW40 51" Rear Projection...
Color separates and picture bows on 9 year old RCA big screen.
Hi, This is a convergence problem and you can set it right by changing the STKs. It is a professional job and i have knowledge of people who ruined their tv by spoiling some miniature surface mounted components close by. You may need to look at pico fuses too. I would say seeek professional help if you not comfortable working with electronics. Check out at www.fixurtvs.com,
Mar 02, 2010 | Toshiba 55H70 55" Rear Projection...
My AIWA TV 19-inch color is 9 years old. It is
HI,
WHEN WORDS AND PICTURES ARE BLUR,DIFFICULT TO SEE,,
ITS PROBLEM WITH LOT (LIGHT OMITTING TRANSISTOR) WHICH INSIDE TV ...
NOT OTHER PROBLEM ..JUST GO TO ECONOMIC TV TECHNICIAN.
TNKS
RABBANEES
Nov 12, 2009 | Aiwa F2000 20" TV
I have a LG 50PC3D when I try to turn on the TV the green light
This is a common problem.i recomend using your warranty if it still applies.if not, try hooking it up to a playstation and play with it.
Sep 07, 2009 | LG 50PC3D 50 in. Plasma Television
Hi. I have an old RCA tv, model # T09081bc. I was hoping to hook up my Playstation 2, but the best result I've gotten was a black screen. I have two different cables for it, one that plugs into the cable...
After you plug the Yellow (video),Red (audio 1) and White if Stero (audio 2) turn the Playstaion on, now turn to chanel 3. does it work? if not look for selector on TV (video input,aux) or use up-dn chanels until you get playstation screen.You can also plug the round antenna cable from TV to unit and set TV to 3 or 4.Good Luck.
Sep 05, 2009 | RCA T09081 9 in. TV/VCR Combo
TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Jul 03, 2009 | Televison & Video
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Sony PlayStation Portable (PSP) Console Logo
62 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
