When wireless light is OFF that is a sign of a bad router, but this can still be fix, you can do this by resetting the router to reset it Press and hold the reset button of the router for 10 seconds while power is ON and then after that reconfigure it back and check also if the wireless is ON already.....
Hello mate,
you will need to connect your computer via Ethernet cable to your router and then access to the router web configuration page and check if the wireless is enabled.
If it's disabled, it's a good news. you will only need to enable it and it will start working.
if it's enabled, in this case there are two possibilities:
1. the wireless is working and it's only the light which is not working, you can verifiy that by scanning wireless available from your pc and see if your router appears in this list.
2. the wireless function is brooken: in this case, you can try to do a reset factory, but this doesn't help you will need to contact your reseller and i hope that the router is still under warranty because it will need a repair or exchange.
Best Regards,
Wireless light on the front of the router is not lit and I am not getting a wireless connection -...
(More)
Wireless light on the front of the router is not lit and I am not getting a wireless connection - how do I troubleshoot (English only please I am not very good with too much techno babble - Thanks)
As a start I have poweerd deown, unplugged, disconnected everything and hit the reset button
says wireless devices none but been on with virgin and they say the line is ok, also says no adsl...
(More)
says wireless devices none but been on with virgin and they say the line is ok, also says no adsl found.
Installed windows 7 64bit now my utilities say no internet connection wheni try to update yet i am...
(More)
Installed windows 7 64bit now my utilities say no internet connection wheni try to update yet i am connected andalso my browser will only operate in 64 bit mode. Please help its driving me bonkers
VPN setup on Belkin N1 Vision Modem Router - feature list suggests it supports VPN but cannot see...
(More)
VPN setup on Belkin N1 Vision Modem Router - feature list suggests it supports VPN but cannot see any configuration settings.
