Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
My LaCie 500GB external harddrive stopped working
We bought our hard drive around six months ago but it abruptly stopped working today. The network cables and battery are all plugged in as far as I can see but it doesn't respond when I press the blue button at all. Nothing has happened to change it's current state (on top a flat cupboard out of reach from liquids/potential damage etc.).
Please help - and would it be possible to recover the files if it has crashed?
  • elaeye Jan 02, 2008
    Actually, I believe I posted this in the wrong place. Sorry about that
  • Phields Feb 02, 2009
    My La Cie makes noises like it's spinning but when I hook it up to the computer, it is not recognized. Can I recover my data? What should I do? I have no problem buying a new one and transferring data as long as I can recover the data.
I have solved the problem, thanks. It was the power cord. I called LaCie and they sent a new power cord. It works fine now.
Posted on Feb 09, 2009
It's the drive's interface. If you open up the case, take the drive out and put it into another caddy, it will work fine. I have had this problem before.
  • 1,006 Answers
Just buy new external
Posted on Jan 27, 2008
My LaCie 500GB External Hard Drive stopped working. Before when I turned it on, I could hear it spinning but now all I hear is a clicking sound. When connected to my computer the computer no longer...
Sorry nothing to do your harddrive is dead. you might be able to open the case and replace the harddrive with a new one. Try searching google or youtube on how to do that.
Regards.
Mar 19, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
I bought a rikiki go 500GB La cie today, and it's making zooming and loud clicking noises, what's wrong?
Your hard drive is most likely dead, you need to call the manufacturer and have them send you a replacement, the warranty should cover this.
Mar 04, 2011 | LaCie Rikiki Go Hi-Speed USB 2.0 500GB...
My lacie hard drive turnes on ,shows that its running,stops running and keeps showing pink light but does not show appearance on my laptop,
Right click "My Computer" and select Manage. In the window, select Disk Management on the left column. If the drive is not listed on the right column, then the BIOS has not detected the harddrive - it might have a harddrive password lock. You will need to go into the BIOS and unlock it with the password.
Nov 01, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hi I have a Lacie External Harddrive 500gb, when I connect my hard drive to my computer it does not open, instead it gives me a message saying that " disk is not formatted"?
The disk was probably dropped or jolted. You can consider the drive bad now. The arm is broken inside. You can format the drive but most likely it won't work after that. Getting the data retrieved can cost up to $2500-$5000.
Nov 30, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
500Gb SimpleTech Ext Drive No Power
Hello.
It sounds like you might have a problem with the power supply.
I have seen MANY external hard drives with failing power supplies. Take it to the store you purchased it from for a check up, it should still be under warrantee if its only 3 months old.
Good Luck!
Jun 17, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this? http://www.lacie.com/us/support/support_manifest.htm?id=10253&guideid=10167
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
External Harddrive Overheated
The disk in side is jammed, try throwing the harddrive like a frizbe but dont let go. That might help unsick the drive
Mar 28, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Can the disc of a external harddrive be change to get your data recovery back
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hard drive won't start up at all
Knowing LaCie the drive might need to be connected to a computer, or need a new battery.  If it is not the battery, try connecting the drive to your computer via ethernet or USB  and you might be able to get the data off of it
Jan 02, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
1,788 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
