Monitors
Generic problem for all Monitors
Monitor "No Signal" RGB Box
shared by 5 users
posted by Schweebs on Jan 02, 2008
There's a permanent NO SIGNAL RGB box on the center of my screen, but everything is working, it's just in the way
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Posted by jentuck on Oct 09, 2008
I have the same problem but with a FPD2275 - everything works fine but there is a "no signal" message in the middle of the screen. I can get it to go away by changing the resolution of the monitor and then changing it back, but it randomly comes back, it is very annoying!
Posted by Guest on Oct 06, 2008
No Signal
Posted by monkeymaniam on Aug 28, 2008
I have the same problem except that the screen blacks out about every minute for a few seconds. this seems like its maybe a connection issue but I tried replacing the cable already. this is very irritating!
Posted by eddie_brown on Jan 03, 2008
I have a emachine W2040 that works but no pix on monitor. all connections are good cables cpu even switched cables this pc was gave to me plus I have a new pc and monitor,i put the good monitor on the emachine still no pix.the emachine has a integrated video should I or can I put a AGP card in the emachine
thank you
ed
Can you Help with these Monitors problems?
Envision EN-7100e 17 in. Flat Panel LCD...
I have an envision 19" lcd monitor that has a blue...
BenQ FP767 (Beige, Black) 17" LCD Monitor
The monitor keeps auto adjusting every 30 seconds or so....
Sony BVM-D14H1U
My Sony BVM-1201 color video monitor is displaying video...
NEC Mitsubishi DiamondPoint NXM76 (Black)...
I have a Diamond Point NXM76LCD Monitor from Mitsubishi...
Planar PT1700M 17 in. Flat Panel LCD...
The cursor shows up way to the left of where I touch the...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
